Results 1 to 7 of 7
Thread: OPUS ATX/M4-ATX - ignition on/off detection if attached to secondary battery?
    Constant Bitrate doncarbone's Avatar
    Aug 2010
    I have a Kinetik HC1400 as my starter battery and a HC800 in the trunk. The two batteries are separated by an isolator.
    If I choose to attach my PSU to the secondary battery in the trunk, will the PSU not operate according to whether the ignition is turned on/off?
    Is there a way around this, or am I just going to have to hook this up to my starter battery?
    Jan 2008
    the ignition position is a key-position, not a battery location.
    so no matter which battery you connect the main power for the psu to, it is the status of +12v on the 'acc/ign' line that determines when the psu shuts down.
    Aug 2010
    does the PSU connect somewhere to this line for it to be able to sense the key-position?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Yes, every intelligent power supply has a wire that connects to your ign wire.
    Aug 2010
    Quote Originally Posted by kegobeer View Post
    sorry to be a bother, but how can i locate this wire...am i having to solder the PSU connector wire onto this somehow, or do most cars come with a plug of sorts i connect to wire to? is there a tutorial or explanation on how to do this properly/safely? it seems like a risky thing to be toying with if you don't know what you're doing....
    Elsewhere
    Search for a wiring harness diagram for your ride: http://www.the12volt.com
    And you don't need the actual ignition wire. Any ignition-controlled line will work. I use the line from a cigarette lighter power, since those are ignition-controlled in my vehicle. You may also have ignition-controlled lines in you fuse box with nothing on them. Add a fuse and use that.
    How about the Wiki?
    Aug 2010
    Quote Originally Posted by DarquePervert View Post
    thank you!
  1. Replies: 6
    Last Post: 06-17-2010, 08:24 PM
  2. Secondary Battery Life
    By markopolo311 in forum Power Supplies
    Last Post: 06-09-2005, 01:43 AM
  3. Replies: 22
    Last Post: 05-01-2005, 03:08 PM
  4. Replies: 4
    Last Post: 10-29-2004, 08:10 AM
  5. Secondary battery?
    By techiejatt in forum Power Supplies
    Last Post: 07-23-2004, 11:00 PM
