Results 1 to 10 of 17
Thread: Relays..
    Oct 2002
    Alaska
    Relays..
    I have a specific question about relays. First of all will this work? I will have 2 amps and my computer that all need to be switched when the car is started. SO:
    I was thinking relay from, battery and switched from the remote lead on my Head Unit. Then the relay feeding into a distro block, and the distro block feeding the "switched" line into the amps remote turn-on terminals, and then powering my inverter.
    Will that work?? and what amp relay would I need?
    thanks, I hope i explained that well...
    Oct 2001
    Ontario, Canada
    why not just tie them all together off of the remote out on your head unit? these devices take very little power on the remote line itself, you probably don't even need a relay.
    However if you wanted to use one, just get any SPST or SPDT 12V relay (you only need < 1A contact current, so any relay will do), and then just hook it up like you described.
    As I reread your post, I see that you also want to power an inverter off of this. How big is your inverter? You can probably just get any SPST or SPDT 12V relay at 20A or 30A which will power a 240W or 360W inverter, respectively. Use the remote line from your head unit to switch this relay as well. I prefer using the head unit because the computer is only on when the radio is on (which really is always) and then I have an easy method of turning it off from the front while keeping the ACC line high, but you could just as easily power it off of the ACC line from the car.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Oct 2002
    Alaska
    so your saying with the 2 amps and inverter I should set it up as I described??
    Oct 2001
    Ontario, Canada
    as I understand your description, yes.
    But you'll need a rather high current relay, which can be expensive (or several lower current ones in parallel).
    Actually if you head down to your neighbourhood automotive wrecker or shop you can probably buy used automotive relays that are like 30-60A for $4-5 each if they are nice to you. These are ones used for your air conditioner, fuel pump, etc and are found in your engine compartment in a fuse panel. One of those will work perfect for what you need.
    Oct 2002
    Alaska
    would 40A be enough?
    http://www.partsexpress.com/pe/showd...ID=15175&DID=7
    And what gauge wire do you think I should run to the inverter, and from the battery?
    Oct 2001
    Ontario, Canada
    40 amps will be perfect, provided that your inverter is less than 450W.
    8 guage (~80-100A) or 10 guage (~60-80A) will do fine for your installation. I wouldn't recommend going down to 12 guage though, you might cut it close and then you won't be able to expand in the future either.
    Just get a good length of 8 guage and run it properly through the underside of the car and into the trunk, then you'll be able to have future expansion as well.
    Apr 2003
    yeah just hook them all up to your head unit's "remote" lead. This turns on once the head unit turns on, it is a built-in relay. It is more than adequate to turn on some amps an an inverter - just don't use it as your primary 12v source..
    Oct 2001
    Ontario, Canada
    The problem is that the inverter doesn't have a remote-in lead, which is why he'd need to use a relay to power it.
    Oct 2002
    Alaska
    hey, you wouldnt happen to know another good store that sells relays would you?? partsexpress rapes you on shipping.. $9 to ship a stupid little relay to me!
    Oct 2001
    Ontario, Canada
