Results 1 to 10 of 15
Thread: start up issue
    Nov 2007
    start up issue
    I am running a biostar mb, 4 usb ports being used, pci dual vga video card. Power supply is a m2- atx. Everything runs fine until a couple of days ago. From Hibernation the boot screen tells me the date and time are wrong, I change it in bios reboot and it works, following afternoon no boot. Pc always goes into hibernation when turned off. I can see the cpu fan turn on and spin but dont see boot screen on monitor. This has happened a couple of times and i rip it out hook up for a bench test and it works. Re install and its gd like nothing happened. Right now I ripped it out and am looking for input as to root of issue.
    I have left cpu in car and tried a bench test using extension cord and psu, got no love.
    thx drew
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    How old is the motherboard? It sounds like the BIOS battery might be dying.
    Nov 2007
    cant be more than 1 1/2yrs, thats the cmos battery right.
    Elsewhere
    Quote Originally Posted by kegobeer View Post
    +1
    Quote Originally Posted by diggla View Post
    Correct.
    How about the Wiki?
    Nov 2007
    Ill try changing the battery, but how does tht affect rest of boot up. Bios doesnt run off psu
    Elsewhere
    That battery provides enough power for the BIOS to retain settings, nothing more.
    How about the Wiki?
    Nov 2010
    Panama City Beach
    To add on to Darque's post - if the BIOS settings are lost, then the entire boot sequence is impacted. Your settings are lost and reset to default, which can affect Windows.
    Nov 2007
    would that be why the cpu does not kick on, or shouldnt I see a boot screen?
    Elsewhere
    Possibly.
    I don't know how you define "boot screen".
    Do you see the POST, or the attempt at POST?
    If the CMOS battery is dead, then you've probably lost your CMOS settings and the POST is halting on a configuration error or somesuch.
    I'd try hooking up a different monitor and seeing what POST tells you.
    If it's not attempting to POST, then there's a completely different issue.
    How about the Wiki?
    Nov 2007
    i get nothing on the screen, just the cpu fan is spinning. This has happened before and what I do is pull it out, bring it in my house. hook everything up and it boots. Then re-install and it works for a few months then back to squar one.
  1. DSATX cold start issue
    By Hectic in forum Power Supplies
    Last Post: 12-20-2010, 04:26 AM
  2. DS-ATX Start up then shut down issue resolved
    By Ineffigy in forum Power Supplies
    Last Post: 02-24-2008, 11:27 PM
  3. Start up Issue..
    By kyjoe in forum General Hardware Discussion
    Last Post: 07-21-2007, 11:10 AM
  4. M2-ATX power issue when car start
    By Alfredbra in forum Power Supplies
    Last Post: 12-21-2006, 08:50 AM
  5. VIA EPIA M10000 start up issue
    By BavarianBuilt in forum General Hardware Discussion
    Last Post: 11-08-2006, 12:51 AM
