Results 1 to 5 of 5
Thread: Power Supply Bench Testing Question
    Jul 2004
    Question Power Supply Bench Testing Question
    I hope this is the right section. I am trying to bench test a aftermarket radio and I was going to use this cheapo jump starter I have for power. I hooked my multimeter up to the jump starter and got a reading of about 13v. I know I am supposed to connect both the red and yellow to the positive (+) and the black to the negative (-) and it should start. However, at 13v, is it safe to hook the radio up or should I wait until it goes down below 12v? It being a cheapo jump starter it doesn't hold a charge that well.
    ø¤º°`°º¤ø
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    °º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°
    °`°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°` °`°
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    ø¤º°`°º¤ø
    º°`°º
    Raw Wave
    Nov 2009
    A 12V car radio should handle up to 16V.
    Cars are rarely as low as 12V - when driving/charging, they normally range between 13.6 & 14.5V.
    It is confusing.
    A "12V" battery is normally 12.67V fully charged; can be 13.6V after charging (with surface charge remaining); is considered fully discharged at ~11.4V unloaded/open circuit but that may mean 10.6V at rated loads, and cranking may dip them as low as 9 or 8 Volts.
    Hence an (or my?) oldskool common design target was that devices should work between 8V and 16V steady-state - or at least not be destroyed between those ranges!
    Jul 2004
    Ok thanks OldSpark, do I need to put a fuse on the red wire or is the fuse on the yellow wire good enough?
    ø¤º°`°º¤ø
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    ø¤º°`°º¤ø
    º°`°º
    Raw Wave
    Nov 2009
    Normally ALL wires connected to a power supply are fused - that's to protect the wires.
    Jul 2004
    Ok thanks.
    ø¤º°`°º¤ø
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    ,¸¸,ø¤º°`°º¤ø,¸¸,
    ø¤º°`°º¤ø
    º°`°º
  1. Noob with power supply/bench testing question
    By seanmac478 in forum Power Supplies
    Last Post: 04-19-2010, 09:09 AM
  2. Bench Testing Power Supply
    By Mears in forum Power Supplies
    Last Post: 07-30-2009, 01:28 PM
  3. Replies: 2
    Last Post: 01-30-2008, 09:32 PM
  4. Replies: 1
    Last Post: 01-09-2007, 06:57 AM
  5. Bench Power Suppy - Amps Needed for testing
    By dorkmanMini in forum Power Supplies
    Last Post: 03-31-2006, 01:28 PM
