Results 1 to 10 of 10
Thread: DCDC-USB Connecting to power button?
    Aug 2009
    Hi, I have a DCDC-USB power supply and a Zotac Mini-PC. The problem is that the power button on the Mini-PC has a led that is always on. If I connect directly to the power button it has a voltage output of about 3V depending on the color of the led, how do I get rid of the voltage so I don't fry the power supply?
    Jan 2008
    are you sure that the led is part of the same circuit as the switch? usually the led is integrated into the switch bezel, but use completely different wire traces.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by soundman98 View Post
    +1
    I have seen the power LED run through the power-on trace before, but these are on OLD dinosaurs with MMX processors and Packard Bell logos...
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2009
    I am almost sure the led is integrated into the power button circuit, it in located in the center of the button itself, the button only has 2 legs, positive and negative, maybe some kind of circuit to solder? By the way it's one of the latest mini-pcs from Zotac ZBOXHD-AD01.
    Aug 2009
    Anyone have any ideas, I am really stuck
    Jan 2008
    pics might help.
    HID retro--100%
    Aug 2009
    Here are the photos of the Power Switch button
    Jun 2007
    Boston MA
    Yeah, +1 for pics. I would be very surprised if there are indeed only 2 contacts coming from the button and they are used for LED power and POWER SW. Sometimes the contacts can be "under" the button so you wouldn't be able to see them. If you discover more contacts, I'd unplug your computer, attach an ohm meter to them and see which ones short when you press the button.
    Jan 2008
    to me, it looks like the power switch traces are completely different then the led traces. though, i have never measured the voltage of the power switch pins, so i can't tell you if the voltage is normal.
    HID retro--100%
    Aug 2009
    Quote Originally Posted by nivanov View Post
    I did what you suggested and the + pin is shorted to any ground on the board when the button is presed, what is also strange, is that there is a resistance of about 50 ohms between + pin and -pin
  1. DCDC USB Power Switch
    By windex in forum Power Supplies
    Last Post: 04-16-2012, 02:19 PM
  2. Connecting Power - Nothing happens...
    By b12buddy in forum Power Supplies
    Last Post: 09-28-2009, 04:30 PM
  3. Connecting the Power Button to the ACPI wires on the Carnetix 2140?
    By noobified in forum General Hardware Discussion
    Last Post: 07-13-2009, 05:26 PM
  4. Connecting the Power.
    By ViViper1 in forum Newbie
    Last Post: 09-26-2006, 05:05 PM
  5. Cheapest DCDC Power Supply? Any for ATX?
    By ryanjg in forum General Hardware Discussion
    Last Post: 08-12-2000, 01:30 PM
