Results 1 to 7 of 7
Thread: Strange power hiccup on m2-atx when turning my car off.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    I recently changed my car PC installation over to another motherboard and as a result changed my power supply back to the m2-atx. Keeping all the components (Power, USB etc) the same i figured it'd be an easy deal. I am now having a problem that i really dont know where to begin troubleshooting. Basically the power to my car PC dips down to <9volts whenever i take my key out of the ignition. It only happens for a second before the multimeter jumps back up to 12v, but its long enough that the m2 cant compensate for the dip and keep my system alive. I can hear the processor fan speed slow for a second before it picks back up and the computer reboots.
    The thing thats kinda baffling me is this really shouldn't be happening. Both of my batteries are less than a year old and the auxiliary battery powers nothing but the car PC and a single (but new) amplifier. I never run the system with the engine off and both batteries still test fine. So where should i start checking? Could a loose wire cause the problem? Again, i'm using all the same wiring, same battery isolator etc. What could cause a dip in detected voltage from a healthy battery?
    Live mp3Car Facebook Chat
    Jan 2008
    so if you turn the ignition off, but keep the key in, the power stays around 12v? but as soon as you pull the key out, it momentarily drops?
    i wonder if it is a worn ignition assembly causing a brief short.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Woodbridge, VA
    Blog Entries
    41
    actually i was wrong.. i just did tests, the power dips when the ignition is turned off, regardless of the key still being in the cylinder.
    Jan 2008
    ok, does the power also dip when you turn the ignition on?(if something is shorted inside the ignition)
    it really sounds like a car problem more-so then a pc issue...(maybe check your cars forum, or a local dealership?)
    HID retro--100%
    Woodbridge, VA
    Blog Entries
    41
    Yes, it also dips during crank. I figured it had to be something with the PC because i never had such problems with my prior motherboard and DSATX power supply
    Jan 2008
    not while the motor cranks, but as you are turning the key from 'off' to 'acc', or 'run'
    HID retro--100%
    Woodbridge, VA
    Blog Entries
    41
    Going from acc to on is fine
  1. Power loss when turning key from IGN to Off
    By borikru in forum Power Supplies
    Last Post: 05-04-2009, 03:43 PM
  2. carpc not turning on with power supply
    By pnyboy27 in forum Power Supplies
    Last Post: 01-28-2008, 10:04 PM
  3. M1-atx power supply not turning mobo on!??
    By XCESIV in forum General Hardware Discussion
    Last Post: 12-20-2007, 12:33 PM
  4. computer not turning on, prob power supply
    By warnockm in forum Power Supplies
    Last Post: 05-11-2006, 09:00 PM
  5. hiccup in mp3s
    By Mike12086 in forum Centrafuse
    Last Post: 12-12-2004, 10:01 PM
