I'm planning to run my Quanmax QBox-1010 mini PC in a car. This box only need +12 volts (no ATX needed), however my audio converter (unbalanced PC output to balanced car system) also needs -12 Volts (negative). Does anybody know about a PSU with +12 and -12 Volt lines? Or should I just go with an ATX power supply anyway?
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
Ok well... as apparently no one has any better idea, I decided to go with the M2-ATX.ATX power supplies have -12 volts and at least I can eve use it later if I decide to switch to an other PC or something...
uh, the m2 atx is a atx-compliant power supply, and your board is not atx-compliant, so you need to trick it into working with a non-atx-compliant board...
you require one of these:
http://store.mp3car.com/Carnetix_CNX..._p/pwr-010.htm
http://store.mp3car.com/Carnetix_CNX..._p/pwr-026.htm
http://store.mp3car.com/DSX12VD_140W..._p/pwr-025.htm
HID retro--100%
Correct me if I'm wrong, but I think "tricking" it only means connecting some of the pins in the ATX connector.
Besides, none of the PSU's you linked are capable supplying -12V.
