Results 1 to 10 of 13
Thread: Can the M2 PSU use input from another PSU to power on and off?
    FLAC WuNgUn's Avatar
    Sep 2007
    I use my M2 to power my monitor and USB hub in the dash, and it's setup currently to monitor the ignition for ON/OFF...except this is draining the battery too fast (M2 + OPUS for the PC).
    I want to run a lead from the OPUS power output to the M2 to trigger the M2's ON/OFF state...
    But it's critical that the M2 stays powered the whole time the OPUS is on (including shutdown sequence) as to not interupt the USB device power...
    Jan 2008
    yes, it should work fine.
    the only problem i see is the 5sec startup delay that the m2 has...
    Sep 2007
    Is that delay always there, even when it is in ATX push button mode?
    Jan 2008
    i believe it is always there, and the only way to remove it was that custom firmware that someone developed..
    Sep 2007
    ****...these M1/2/3/4 PSU's are garbage!!
    Sep 2007
    Manual...
    When all config jumpers are removed, M2-ATX-HV will be in the “dumb PSU
    mode”, no ignition timing, no HARDOFF. M2-ATX-HV will send a gratuitous “ON” pulse
    to the M/B when power is applied for the first time...
    Since it's not hooked up to a mainboard, will the M2 actually power on and off then?
    Jan 2008
    that's why i use a dsatx....
    that section is just talking about the J7 jumper activity..
    that might be the way you need to set it up, but you would need to add a relay to cut power the +12v constant line so the opus can control it.
    Sep 2007
    Jeez...maybe I'll just make my own 12V and 5V regulator and forget the M2 altogether!
    Or like you say, a relay controlled by the mainboards PSU.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by WuNgUn View Post
    No, but can be,
    You will need to short the PWR OK pin to gnd.
    Sep 2007
    Done that already...
  1. Which power supply to use for a Pc with 19v input
    By hailrazer in forum Power Supplies
    Last Post: 08-20-2009, 07:40 AM
  2. inverter input power?
    By archaic0 in forum Power Supplies
    Last Post: 04-30-2007, 05:00 PM
  3. Switching Power Input
    By Anshu in forum General Hardware Discussion
    Last Post: 06-28-2006, 11:02 PM
  4. DC input to ATX power supply
    By mikemccoy in forum Power Supplies
    Last Post: 01-26-2006, 11:55 AM
  5. Thoughts regarding power input?
    By Skraggy_uk in forum General Hardware Discussion
    Last Post: 03-09-2004, 04:22 AM
