Results 1 to 6 of 6
Thread: Not a Conventional Power Button Prong?
    May 2008
    so I'm trying to setup my Car PC inside the house using a regular power supply and when i go to use the power button prong on the Motherboard i notice that instead of it having 2 prongs (a + and a - ) there is only 1 Prong for Power SW.
    so how the hell do i start the pc?
    here's a pic of what i mean
    Jan 2008
    what model motherboard is it?
    May 2008
    Quote Originally Posted by soundman98 View Post
    Jetway 7F2WE1G5D-OC-LF
    can't find it on the website but this is the closest model number and it looks very similar:
    http://www.jetway.com.tw/jw/ipcboard...=J7F2WE1G5S-LF
    May 2008
    nvm... i figured it out... it's the wrong Prongs even though the legend is right next to it.
    it's like so:
    Jul 2011
    It does say JW_FP below the right prongs though, doesn't it?
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    Those three prongs that you thought were power LED and power switch are actually a 2nd set of headers for a 3prong power LED. Jetway is nice about this; they offer 2 prong and 3prong headers for your case's LED's since cases tend to vary there.
    Jetway ran out of room on the PCB near the FPanel so they had to put the "map" over there. This is fairly typical with Jetway mainboards in general
  1. non-conventional install and power supply
    By jersey in forum Power Supplies
    Last Post: 06-05-2005, 01:11 PM
  2. Mobile CPU VS Conventional CPU ??'s
    By J-Fame in forum General Hardware Discussion
    Last Post: 02-18-2005, 10:25 AM
  3. Good alternatives to conventional CarPC's
    By e_fractal in forum General Hardware Discussion
    Last Post: 11-29-2004, 01:33 AM
  4. Need help with shorting out a 4 prong switch
    By Adam F in forum General Hardware Discussion
    Last Post: 04-12-2002, 01:38 AM
  5. grounding the third prong ?
    By Axkicker in forum General Hardware Discussion
    Last Post: 06-29-2000, 08:41 PM
