Results 1 to 3 of 3
Thread: Problems waking from sleep
    Jul 2011
    Hi,
    Not sure if this is the right forum for this - apologies if not - couldn't see anywhere more relevant...
    Anyway, I have a D525MW motherboard, fitted with 4gb RAM and a 120gb Runcore SSD, running Windows 7 Pro with S3 Hybrid Sleep enabled.
    Power supply is a M3-ATX with the config set up so it will wait 10 minutes for the motherboard to power down before powering it off and then hard-off at 18 hours. This should mean that if the car is used within 18 hours of the last use, the PC should resume from sleep, but longer than 18 hours will cause a resume from hibernate.
    When I turn the ignition on after leaving the car for a few hours, the PC seems to randomly start from the POST and display the "Windows didn't shutdown correctly" screen, but other occasions it resumes from sleep fine.
    I suspect that either the M3-ATX is powering down before the 10 minutes is up and therefore the sleep hasn't completed properly, or Windows doesn't sleep at all, and after the 10 minutes has expired just powers down "uncleanly".
    The video card blanks whilst this is happening, so I'm at a loss as to what is happening...
    I've been through all the settings I can think of and checked the wiring etc, but can't work out why this is happening - does anyone have any ideas what I can do to work this out?
    Cheers
    Snap
    Jan 2008
    have you tried the components using a standard atx power supply in the house?
    i think the first-best step is to try to eliminate or prove that the power supply is the culprit.
    Jan 2011
    I have the exact same issue with the same motherboard and power supply. If I set win 7 to "sleep" it works fine, if I set it to "hibernate" it works fine. As soon as I set it to "Hybrid sleep" it fails as described in the original post. Anyone had any success getting this going?
    Thanks,
    Mike
  1. Replies: 2
    Last Post: 07-18-2011, 05:30 PM
  2. Problems waking from sleep with GPS
    By IrmscherV6 in forum Road Runner
    Last Post: 01-05-2011, 01:29 PM
  3. Help on waking up a mac mini in safe sleep...
    By crazysmurf in forum MacCar
    Last Post: 10-15-2007, 08:14 PM
  4. ICT - Problem waking from sleep
    By gthing in forum Other Cool Front Ends
    Last Post: 05-06-2007, 02:06 AM
  5. Mini Waking Up, Going Right Back to Sleep
    By gthing in forum MacCar
    Last Post: 01-29-2007, 05:57 PM
