Results 1 to 4 of 4
Thread: How to mount M2-ATX in non-conventional case.
    Jun 2011
    Sooo, I basically DIYed a case out of an old microatx case, making it much smaller and more suited to my needs. Now, the only place to mount my m2-atx is on a bare aluminum portion of my case.
    I don't know much about electronics, but I do know that mounting straight onto aluminum can't be good... so, what are my options? Could I get away with using thick double sided tape to make a "platform" of sorts to mount it on?
    I don't have access to standoffs so that's not an option
    Jan 2008
    i was originally going to say that it would work.
    but i am a little worried that with constant pressure, some of the solder joints could poke through the double sided tape and short out.
    what about mounting the m2 to a sheet of plastic(like this), and then use the double sided tape to mount the plastic?
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    http://www.mcmaster.com/#threaded-standoffs/=dhbkj2
    i would recommend using M3 metric thread (fairly typical machine screw with mini-itx computers)
    or you could use 6-32 american thread (fairly typical with ATX computers)
    a length of 5-10mm should be fine, obviously depending on your case and space allotment
    drill a couple holes somewhere, mount those up, good to go
    Jul 2007
    Arkansas
    Washers, bolts, and nuts. You can build your own stand offs with these that will be perfectly function and won't risk shorting (as soundman98 mentioned). Use a bit of lock tight to keep vibrations from causing any looseness.
  1. How to mount the case
    By mazda8 in forum Newbie
    Last Post: 05-23-2009, 10:40 PM
  2. Mount a M4 to an ITX case
    By chipmaster in forum M4-ATX
    Last Post: 03-10-2009, 07:05 AM
  3. Ways to mount the PC without a case
    By stylz in forum General MP3Car Discussion
    Last Post: 02-25-2009, 04:39 PM
  4. Computer Mount/Case
    By JWise1203 in forum Fabrication
    Last Post: 11-16-2005, 08:23 AM
  5. Building LCD, Case, & Mount
    By kgoode80 in forum LCD/Display
    Last Post: 06-27-2002, 02:02 PM
