Results 1 to 4 of 4
Thread: weird sleep/wake problem
    SAV
    SAV is offline
    Oct 2009
    Recently built a carputer, having a weird problem with my m2-atx, running Windows XP btw.
    It seems that when I turn off my ignition, the computer attempts to go to sleep and eventually turns off.
    When I start the ignition, the computer first wakes up, turns off, then turns back on fully (starts with BIOS, goes to XP boot screen) and eventually reboots fully (this takes forever!)
    Any suggestions? Seems like it's not sleeping/hibernating/or even shutting down properly....
    Thanks!
    Jun 2007
    Boston MA
    Quote Originally Posted by SAV View Post
    Thanks!
    Maybe your power supply isn't surviving engine cranks? How soon after you crank the engine does your computer turn on. If it tries turning on at the same time as you are cranking, there voltage drop might cause loss of power to your PC.
    Jan 2008
    ^ a easy way to test that would be to turn the car to 'acc' or 'on', without cranking the motor.
    SAV
    SAV is offline
    Oct 2009
    well its more like it shuts down instead of sleep or hibernate.
    is there another way to configure the M2-ATX other than those jumper settings?
  1. How does the Carputer wake and sleep?
    By bebopblues in forum Newbie
    Last Post: 05-11-2009, 11:48 PM
  2. 'No Signal' on wake from Sleep
    By hammer32 in forum MacCar
    Last Post: 07-06-2008, 12:13 AM
  3. Weird Wake-Up Problem
    By gthing in forum MacCar
    Last Post: 05-25-2007, 02:04 PM
  4. Sleep &*Wake up control
    By Jirka Jirout in forum MacCar
    Last Post: 03-13-2007, 12:32 PM
  5. Found this. Power/Sleep/Wake Hot Keys
    By themolt in forum Input Devices
    Last Post: 03-25-2005, 10:52 PM
