Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: PSU choice?!
  1. #11
    fxg
    fxg is offline
    Newbie fxg's Avatar
    May 2011
    Bucharest, Romania
    IT seems that the M2-ATX is not in stock, and there's no known date when it'll be available.
    I see that the M4-ATX has got pretty good feedback on cartft.com: http://www.cartft.com/catalog/il/903
    Any thoughts on this? My choice seems to be already made up by the local retailers, though. I hope it'll work...
  2. #12
    Jan 2011
    My Car PC is based on the exact same motherboard as yours and I use the M3 PSU. I selected it because of its size, since I can fit it all in a M350 case and keep it all tidy. I also power through the M3's molex connector my monitor(VM70) and a usb hub that I have up front and I have no issues with lack of power, since that motherboard uses really low amounts of power.
  3. #13
    Jan 2008
    i was really recommending the m2 over the m4 because of the size. the m4 will not fit in any carpc case, where the m1-3's will. not sure if that matters(it doesn't to me!), butit is something to keep in mind if you want to install everything in a case.
    otherwise, i don't believe there are any serious issues since they revised the m4 pc board(it still might have some power traces going over the mounting points, so always use non-conductive hardware to mount it)
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  4. #14
    fxg
    fxg is offline
    Newbie fxg's Avatar
    May 2011
    Bucharest, Romania
    I managed to get the M2-ATX in the end. Fits perfectly in my case [JNC Cute-Q1] and has the same mounting points as the PSU that came with the case.
    I'm taking care of the s/w install / tune-up and I'm using the P1 setting on a 12V, 65W power brick. The PSU seems to work just as advertised, but until I get it in the car [which is gonna take a while], I'm still a bit skeptic I need to see it handle the engine crank on my diesel engine [which takes quite a bit of power to start].
    Thanks for the help! I'll come back with photos next week, but it came out pretty nice
  1. Good choice for an In-Car USB hub?
    By patkevin in forum General Hardware Discussion
    Last Post: 10-04-2010, 07:09 PM
  2. OS of choice?
    By disasm in forum Software & Software Development
    Last Post: 05-22-2006, 10:31 AM
  3. Equipment choice
    By doof205 in forum General Hardware Discussion
    Last Post: 09-19-2005, 04:29 PM
  4. HDD choice
    By MrSpace in forum Newbie
    Last Post: 07-07-2004, 05:16 PM
  5. Lcd Choice???
    By odin836 in forum LCD/Display
    Last Post: 08-19-2003, 10:31 AM
