Results 1 to 10 of 14
Thread: PSU choice?!
    fxg
    fxg is offline
    Newbie fxg's Avatar
    May 2011
    Bucharest, Romania
    PSU choice?!
    Hi guys,
    I'm slowly building my first CarPC, and I've run into a bit of a problem concerning the choice of power supply.
    I'll need to power up an AsRock E350-M1 mainboard and I can only chosee between the M1 to M4-ATX series or the PicoPSU.
    Which would you recommend? I'm looking for stability, features and, of course, the one with the least known problems
    These are the only things I can get: http://www.pcgadget.ro/Surse-ATX-PicoPSU-FANLESS.html [ignore the Romanian text, the models are quite clear though].
    Thanks!
    Jan 2008
    well, i can rule 1 out right away-- do not use the pico psu. these require regulated 12volts-- cars voltage is usually around 12 volts, but can go from 5v to 15v. the pico psu just sends that to the motherboard--it will kill computer parts.
    though, after reading a little more(i do not understand russion, so that could be part of the problem) it seems to refer to the M3 as a pico psu as well.
    if the site is just refering to the small size of the psu, then it is a different story.
    i believe all Pico PSU models(the ones to avoid) use a yellow 20 pin connector
    can i ask why you are only deciding between the m1 + m4? there are 2 models in between that could work as well.
    you really need to look at what you want to power with the psu, and then add up the approximate maximum power consumption of each device to see what product best fits your needs.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    fxg
    fxg is offline
    Newbie fxg's Avatar
    May 2011
    Bucharest, Romania
    I couldn't agree more, unfortunately I don't get much of a choice in my part of the world.
    Also, what I meant to say is that I can choose from the Mx series.
    Jan 2008
    ok, for your board only, the m1, or m3 should be plenty, but the most common psu for that type of board is the m2..
    the m4 would also work, though is a lot more money upfront. if you plant to eventually upgrade to a more- power-hungry pc later, then it is a worthwhile investment, but is not needed in your current build.
    HID retro--100%
    fxg
    fxg is offline
    Newbie fxg's Avatar
    May 2011
    Bucharest, Romania
    Alright, but output power aside, which is the most "bug free" of them? And by that I mean available settings that actually work, engine crank resiliency [I drive a diesel car so it needs quite a bit of power at start-up].
    I'm only asking because I've seen so many threads regarding firmware problems, electrical noise, etc...
    Jan 2008
    for product support/reliability, i recommend the dsatx(zootjeff provides excellent support), or a opus series-- i know, neither are available in romania..
    i have not been very happy with what i have read on any of those psu's you have available...
    there is some debate that they are so popular, that the problems with them probably are not any worse then any other psu if based on a percentage of psu's-sold, but the market size is so much larger that there seems to be more problems..
    as i said, the m2 seems to be the most popular model, so it might be the best one to go with..
    HID retro--100%
    Mar 2006
    Colorado, but Canadian!
    The M2 works well for what it is. FYI, mp3car.com ships everywhere. And the UK based CarPC retailer should ship there too.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    I can recommend the opus.
    The epitome of Function over form and is probably the best Car PC in Europe.
    Visit my Homepage
    fxg
    fxg is offline
    Newbie fxg's Avatar
    May 2011
    Bucharest, Romania
    I might go with the Opus or the DSATX, but there are more things to consider. Like warranty, transport charges, etc...
    I guess, considering my choices, that it all boils down to M2 vs M4 ATX.
    Both would be powerful enough for what I'll throw at it, but which one would you recommend? I'm looking for the one least likely to give me headaches
    Jan 2008
    i would probably go with the m2. the problems i have read of seem to be less severe, and it also seems there are many, many more m2 users..
    HID retro--100%
  1. Good choice for an In-Car USB hub?
    By patkevin in forum General Hardware Discussion
    Last Post: 10-04-2010, 07:09 PM
  2. OS of choice?
    By disasm in forum Software & Software Development
    Last Post: 05-22-2006, 10:31 AM
  3. Equipment choice
    By doof205 in forum General Hardware Discussion
    Last Post: 09-19-2005, 04:29 PM
  4. HDD choice
    By MrSpace in forum Newbie
    Last Post: 07-07-2004, 05:16 PM
  5. Lcd Choice???
    By odin836 in forum LCD/Display
    Last Post: 08-19-2003, 10:31 AM
