Results 1 to 3 of 3
Thread: Help! Ignition wire slow to discharge
    Mar 2011
    hi I have a carnetix p1900 and have the yellow ign wire tied to the ignition (0V when off, 12V when on) in my 2005 honda accord. However, sometimes the ignition voltage seems to take long to discharge. It would have a constant 12V for minutes (as long as 5 to 15 minutes) after the car has been turned off and the key removed. Does anyone else experience this? How can I resolve this? Thanks!
    Jun 2011
    Use a different source for your switched +12v?
    Just use a volt meter and find one that always turns off with the key
    Mar 2011
    Ohio
    It sounds like you have the +12VDC source that stays hot after the key is turned off that allows you to roll the windows up and down until you open the door, or it times out. I know that I've sat in the car after turning the key off and after 5 to 10 minutes I hear a relay click. It sounds like you need to find another source.
    Also, just to be technical, when I read "discharging" I though the voltage was decaying, not just switching off after 5 to 10 minutes.
    I don't have the wiring diagram for a 2005 Accord, but it should not be too hard to find. I like the Haynes Manuals that can be purchased at most auto supply stores. A cheap voltmeter is also a must-have. Good Luck!
  1. ignition wire
    By neo-ninja121 in forum M2-ATX
    Last Post: 02-23-2011, 08:39 PM
  2. best use for ignition wire?
    By mmayn412 in forum Power Supplies
    Last Post: 08-06-2009, 05:37 PM
  3. ignition wire
    By TeamRSX in forum Car Audio
    Last Post: 05-16-2008, 10:53 AM
  4. Ignition wire
    By ViViper1 in forum Power Supplies
    Last Post: 11-19-2006, 10:10 AM
  5. 24 AWG ignition wire
    By chewy747 in forum Power Supplies
    Last Post: 05-27-2006, 10:23 PM
