Results 1 to 4 of 4
Thread: Modifying M4-ATX
    Jan 2007
    Modifying M4-ATX
    I have this intelligent power supply from my previous carPC setup:
    http://www.mini-box.com/M4-ATX
    Now I have bought this little nettop:
    http://www.fit-pc.com/web/
    This little thing needs 12V DC regulated power.
    I does not have startup/shutdown controller integrated, so I want to use M4-ATX to power fitPC2 with 12V.
    Anyone knows how to do that, because M4-ATX has standard MBO connector, there is no separate stabilized 12V output.
    Will startup/shutdown functions remain working?
    Thanks.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You just need to take a feed from any of the Drive power connectors, Yellow and black will provide 12V out.
    The only 'mod' needed to get it to work without a Normal MB connected is to short out the green wire with any black in the MB connector.
    This is basically the PWOK from the MB telling the PSU that it is connected OK.
    Jan 2007
    What will happen with shutdown/startup functions?
    I assume that they will still work?
    Maybe I should try connect it that way and see what happens
  1. Modifying
    By cdamania in forum Fabrication
    Last Post: 06-06-2008, 10:31 PM
  2. Modifying CNAVClickedLocationOverlay
    By tomcat in forum StreetDeck Skins
    Last Post: 08-24-2006, 03:39 AM
  3. Modifying Iguidance 3.0
    By XCaLiBuR1085 in forum GPS
    Last Post: 08-02-2006, 11:37 AM
  4. Modifying car psu to get 12V
    By Phreak Show in forum Power Supplies
    Last Post: 05-17-2006, 10:26 PM
  5. modifying the windows
    By redbullah in forum Software & Software Development
    Last Post: 03-27-2006, 05:36 PM
