Results 1 to 10 of 11
Thread: uSDC or Micro-Shut-Down-Controller help!
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I've been basically killing myself on how to automate my PC which uses an inverter. I opened another thread a long time ago, and yesterday realized I couldnt never achieve what I wanted to do all alone. So I went ahead and bought the uSDC or Micro-Shut-Down-Controller from MoCoSo.
    My issue is that I do not understand the schematics on setup at all. It seems like the PSU is in the picture, but there is no reference to what happens to the Inverter. Shouldnt the controller be controlling that? Can someone please explain this to me? Many thanks!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jul 2007
    Miami
    OK, I understand them. I just dont know how the inverter falls into place.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Nothing in the manuals that will help?
    http://www.mpegbox.net/microsdc/
    If you are using this to turn on the inverter, which then powers the pc, shouldn't it be wired to the inverter like you'd wire the anti-thump from an intelligent power supply to an amplifier? It looks like the connection diagram on the main page of mpegbox.net/microsdc shows how things should be wired.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jul 2007
    Miami
    Here is what I came up with. Is this correct?
    Name:  inverter setup.JPG
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jul 2007
    Miami
    Quote Originally Posted by kegobeer View Post
    The manuals confuse me because they make no mention of the inverter. The way its done, it seems they have it connected directly to the PSU of the PC. Its like they left the Inverter out. Im hoping my drawing up abouve is correct?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Nov 2010
    Panama City Beach
    I didn't find anything on the website mentioning an inverter, so that's probably why you don't see anything about it. If the relay turns on the inverter, then that looks right.
    You probably already thought about this, but make sure there's some sort of delay for turning off the inverter after you turn off the ignition.
    Jul 2007
    Miami
    from reading the manual, thats what the computer sense line is for, or at least thats what I got from the instructions. I think i'll have to wait and see when the controller comes in.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Aug 2009
    Melbourne, Australia
    Yes this will work just make sure the Amps/Volts rating of the relay you use to replace the inverter switch is high enough.
    It may be stamped into the switch or trace the wires back to the PCB and see if it is labled.
    But as a side note I personly would never use an inverter full time as the dangers well outway using a DC - DC supply.
    Jul 2007
    Miami
    Quote Originally Posted by MagicMan View Post
    Well the relay will not be in contact with the actual inverter line. It will be wired into the inverters on and off switch. Judging from the gauge of wire the switch uses, a 20amp relay should be fine.
    The switched is wired, so im planning to just remove the switch, extend the wires and connect to the relay.
    I do not know if you know, but my multizone setup uses a 550 watt PSU. There is no DC-DC PSU that powerful. The PSU is powering a AMD Phenom II x6 with 12gb of RAM and a fairly power hungry graphics card. I made sure to buy a very well reviewed inverter, rated at 600 watts continuous and 860 watt peak. So I think I will be OK.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jul 2010
    The inverter is hooked up to your battery (or a spare), correct? If so, why not 'cut' one of the wires from the battery to the inverter, and use a relay tripped by your acc/ign wires. Works for turning it on/off when your vehicle is on/off. You would just always leave the inverter turned on, but power would be cut or applied via your ign state. Shutting down a system is another story though...
    If your trying to find some "smart" shutdown procedure without using a dc/dc psu, well, I have no idea where that would come from. Via lack of sleep, I can only think of getting a dc/dc psu and not really use it, but use the turn off feature. Would require more relays and splicing into the mobo on/off headers for those relays. Doubt you want much wiring at this point though
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
  1. WTB UsDC Micro Shutdown Controller
    By dasha877 in forum General Hardware Discussion
    Last Post: 02-23-2006, 09:38 PM
  2. Clicking Shut Down Controller
    By dpinkston in forum Power Supplies
    Last Post: 10-24-2005, 10:30 PM
  3. where can i get one of auto shut down controller?
    By iPal in forum Power Supplies
    Last Post: 09-20-2003, 11:48 PM
  4. Opus Shut Down controller
    By binary.h4x in forum Power Supplies
    Last Post: 08-25-2003, 09:48 AM
  5. Shut down controller
    By danl in forum Power Supplies
    Last Post: 10-16-2002, 02:29 AM
