My suggestion would be to use the M4ATX, just from personal experience, ive had the same one for over 5 years and no problems, plenty of power!!!
Feel free to check out my installs if you like and my LCD gauge panel set up.
Title says it. I will be building my first carputer and as far as power supplies go I am quite lost at the moment. Any input would be appreciated.
I would like a power supply which can start the computer with a reference from the ignition status. I would also like to be able to bypass the ignition reference feature with the flip of a switch for ECU tuning purposes, is this possible?
I will be running a mini itx board with a 1.6GHz dual core AMD E-350 cpu , 8 GB of ram, a 2.5 form 60GB solid state drive, an internal pcie sound card and I will be using onboard video for a dual screen setup.
Here's some of my parts:
http://www.newegg.com/Product/Produc...82E16813128468
http://www.newegg.com/Product/Produc..._-Pst01Descrip
http://www.newegg.com/Product/Produc...82E16820139075
How much power would I likely be needing? Any suggestions on a particular power supply? Again any input is appreciated.
Thanks for the input. Any other suggestions?
with that board, i think the m2 would suit your needs just fine. though, i am partial to the dsatx because i've got one...
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
