Results 1 to 6 of 6
Thread: D945GSEJT no green standby light
    Newbie wmguk's Avatar
    Aug 2010
    Nr Norwich, UK
    Hey Guys,
    I have an Intel D945GSEJT which has been working fine, I've been to use it today and nothing happened, so checked the power and connections, all fine - the 4 pin feed on to the board shows the correct 12v however the board doesnt show its green light - which has always been on before...
    Are there any checks I can do or do I just assume the board is now dead?
    Any thoughts?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Take it out and connect it to a desktop power supply (or use the brick that came with it) and see if it powers up. I had this issue with mine, and I ended up removing the BIOS battery for about 10 minutes and then resetting the BIOS, and it started working again.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Aug 2010
    Nr Norwich, UK
    hmmmm, ok, ran it on the psu brick, and nothing.... removed the battery, disconnected everything - its been over an hour, looks like its dead
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    If you have a DVM, check the on board fuse near the power connectors.
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
    Aug 2010
    Nr Norwich, UK
    Hey,
    I've just looked at my board, but I can 3 chips that may be fuses, any ideas which one it is?
    May 2010
    Detroit, MI
    see pic
  1. Is My M4 Dead....Blinking Green light!!!
    By locs4dayz in forum M4-ATX
    Last Post: 12-13-2010, 08:40 AM
  2. PSU for D945GSEJT
    By sckeLL in forum Power Supplies
    Last Post: 11-01-2010, 06:44 PM
  3. 60 mw Green Laser for urban light graffiti
    By Fiberoptic in forum Off Topic
    Last Post: 08-06-2010, 01:37 AM
  4. Replies: 14
    Last Post: 12-10-2005, 10:29 AM
  5. Green squares after Standby??
    By stoodo in forum Road Runner
    Last Post: 04-13-2005, 01:50 PM
