Results 1 to 5 of 5
Thread: m2 160w psu
    Jan 2012
    m2 160w psu
    hello! just started a car pc project in a volvo s60.
    just bought a ASUS E45M1-I DELUXE, AMD E-450 motherboard, and i read in the manuel it recommandes at least 350w psu in full configuration.
    i also have bought the m2 atx 160w psu some month ago, can i use this?
    what are the signs if the psu is to weak? lower voltage? startup problems? will be running a 128gb ssd disk.
    i guessing it will hold at startup at such, but i want to know the signs just in case so i can monitor it
    Jul 2011
    Sydney Australia
    Should not be a problem. However, if it is a problem. Some signs would be:
    System wont start.
    System crashes as it tries to boot O/S(blue screen/green).
    System crashes as it tries to shutdown(blue screen/green).
    CPU uses most power at boot up and shutdown process(carpc use).
    Check cpu specs to see what the max. watts it uses at peak performance. If its max watts is less than say,80w it should be fine provided that other components such as Ram/usbs are not drawing too much power.
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    It's a fusion powered motherboard. You do not need anywhere near 350 watts.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jan 2012
    great! thanks a lot, just the info i was looking for
    Jan 2012
    good to know, i stated that i read it from the motherboard manual, and it was in full configure. but thanks anyway
    here is the build thread on my car.
    after i'm finished i'm going to put a thread here as wel for the volvo users
  1. M2-atx 160w
    By ctx32 in forum Power Supplies
    Last Post: 08-14-2008, 11:07 AM
  2. M2-atx 160w
    By Bullwinkle777 in forum Power Supplies
    Last Post: 04-09-2008, 09:36 PM
  3. FS/FT M2-ATX 160w
    By dasaint80 in forum Classified Archive
    Last Post: 02-28-2007, 01:40 AM
  4. Wtb: M2-atx 160w
    By Monkee in forum Classified Archive
    Last Post: 09-05-2006, 09:04 PM
  5. 160W 12V ATX DC-DC $105
    By Twostep in forum Power Supplies
    Last Post: 12-21-2001, 08:02 AM
