Results 1 to 5 of 5
Thread: m4 or m2 atx power supplys
    Apr 2010
    hi, whats the difference between the m4 and m2 atx power supplys, just putting together my car pc and just wanted to clear this up before i waste money on the wrong one..
    thanks daveo
    Jan 2008
    the shape and the power output. and the m2 requires a 4pin-flat to 4pin-square adapter for boards that require cpu power.
    Apr 2010
    hi, thanks for the reply, so how do i know what one i need or is best to use
    thanks daveo
    Jan 2008
    check one of the many online computer power calculators, and use the one that works for that power amount.
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    http://www.epiacenter.com/powersim/p...mulator_v2.htm
    you could list what hardware you plan to use and we could give you some better advice
    the M4-atx is a bit more work to get mounted
    the M2-atx is usually a drop-in replacement for "dc-board" type cases; ie - 5677, 3688, GA677, etc
    m4-atx operates @ 6~30 V and puts out a peak of 250w
    m2-atx operates @ 6~24 V and puts out a peak of 160w; alternatively the high voltage M2-atx is 6~32 V and 140w
    there's other differences as well, but it would help to know what your plans are for MB, CPU, HDD's, and other major peripherals (LCD, audio card, gps, etc)
    cheers!
  1. Combining Power Supplys?
    By majasticmoose in forum Newbie
    Last Post: 01-06-2010, 04:01 PM
  2. HOT OR NOT ? Power Supplys and Heat
    By Draxx in forum General MP3Car Discussion
    Last Post: 08-19-2006, 07:01 PM
  3. power supplys
    By enderwiggin9969 in forum Newbie
    Last Post: 02-13-2006, 05:54 PM
  4. mini-ATX power supplys
    By Joker in forum Power Supplies
    Last Post: 11-29-2003, 11:36 PM
  5. small power supplys
    By Aladdin in forum General Hardware Discussion
    Last Post: 02-26-2000, 10:19 PM
