Results 1 to 4 of 4
Thread: how do I make my inverter automatically on and off?
    Apr 2002
    socal
    I would like to make my inverter turn on when I turn the ignition on and turn off after I turn off the ignition. How do I do that and what parts do I need? Thanks.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Search for relay and inverter.... then read
    TruckinMP3
    Read the FAQ!
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Yep, used a relay, but mine works off the Headunit antenna/remote line.
    The relay is fitted into the fused inverter red wire that goes to the battery, and is triggered when you switch on the Headunit.
    4x4 in a turbo stylee.
    Constant Bitrate cubanmoses's Avatar
    May 2003
    miami/orlando
    man, i was about to post something on this, but i found wha ti was looking for. that's the same wire i have my lcd polugged into and my radio, if i connect the power inverter to that wire, would that be fine?
    also, i got one of those car/airplane power supplies, so i can remove the car adapter and two wires are there. i rather not cut the wire and void the warranty in case comething ever happens to the power inverter, so can i rig some wire to go to the remote wire from the power inverter?
    project: built, updating software
    comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
    software: nlited xp, roadrunner
    screen: TM-701L touchscreen
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    future: gps with and navigation software
