Well.... that's a switch - there is no minimum current for A-B (pins 1 thru 2), it only has a max allowance of 100mA with a 0.5V - 7V range.
Its On resistance is ~5 Ohms and assume a leakage current of 10uA.
The Enable (OE; pin 4) must be low (below ~0.5V) for AB to conduct.
It's what's beyond that switch (A-B; pins 1 & 2) that determines what is required - unless the "Enable" (OE-bar) is the "remote on" etc.
LinkBack URL
About LinkBacks
