Results 1 to 8 of 8
Thread: Having problems with power supply.
    Jul 2012
    Wolverhampton, UK
    Hi all, im new here. Seems like a good place to get help so here goes . I am trying to setup a media center for my car. I am using a pentium 4 3ghz and the mobo is a Medion Ms-6719. Looking around I purchased a power supply from flea bay. Its labeled as a M2-ATX 160w and says for "Full power pentium 4". However, the system will not start the post. I connected a Amp meter in-line and the whole set-up is only pulling 1.2A even at initial connection. The system boots with the conventional power supply. Could this be a faulty power supply? Thanks.
    Jan 2008
    did you have the power button wire connected from teh power supply or did you trigger it manually?
    it is very possible that the psu was faulty, but it would probably be a good idea to test it with a psu tester to try to verify it first.
    Elsewhere
    Also, that P4 may draw more power than the M2 can put out. I'd check the electrical specs of your specific P4 variant against the output of the M2.
    How about the Wiki?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I know this sounds stupid but was the P4 power connector connected? That's been my problem on a few occasions.
    Tidder
    Try RevFE
    Jul 2012
    Wolverhampton, UK
    Thanks for the response guys, its much appreciated. Just to confirm the cable to the switch is connected and the 4 pin molex to the motherboard is connected. On this power supply there is a 4 pin output already. I know some need splitting but luckly this didnt.
    I have checked the power requirements of the system on eXtreme power supplies and it says 128w minimum 178w reccomended with the onboard graphics and 1 hdd and 1 stick of memory and 2 usb sticks. Its the Northwood processor which uses less power. I did take the supply to my local computer shop who kindly charged me 15 to tell me the 12v, 5v and 3.3v rails are all good. I asked the power output of the psu and he replied "I dunno" and looked at me like I asked for his sisters phone number or somthing. I could have told him that.
    Quick question, is there only one rail for 12v on these psu because a continuity test through the red cables says so. i.e if the psu assigns for example 80watts to the 12v supply then 80watts can supply the processor and mobo, however, if you plug in a hdd then it takes say 20watts away from the 80watts or are they split into processor/mobo/hdd ect. Do you get me?
    Sep 2003
    New Mexico, USA
    Red = 5v. Yellow = 12v.
    I have personally ran a northwood 2.0ghz and a couple gigs of ram off of an M2 and something else that was 120w. I'm not sure what the issue could be really. Maybe just a weak M2?
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    What are you using to supply the M2 with power?
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    Oooh! Also, I've only had this happen with one build but might be worth a try for troubleshooting. I had a motherboard once that had some bizarre PSU timings and would try to POST before the voltages normalized I think. Hit the reset button after the initial power on and it would POST and boot away, ran like a champ.
    Tidder
    Try RevFE
  1. Problems with my power supply
    By VXCompyBox in forum Power Supplies
    Last Post: 10-10-2009, 06:29 AM
  2. Powering DSATX with atx power supply problems
    By m0f in forum Power Supplies
    Last Post: 06-02-2006, 01:02 PM
  3. Opus Power Supply Problems
    By IxTanGxI in forum Power Supplies
    Last Post: 11-27-2005, 03:34 AM
  4. Power Supply problems
    By c-dawg in forum Power Supplies
    Last Post: 05-23-2002, 11:15 PM
  5. Power Supply Problems Solved
    By Catlas in forum General Hardware Discussion
    Last Post: 08-15-1999, 11:34 PM
