Quote:
Originally Posted by
OldSpark
redheadrod, surely you jest...
Although battery differences are why you do not keep them paralleled (nor mix in series), those difference mean little during charging. And when being loaded, paralleling will increase capacity unless one is faulty or at a different capacity (percentage-wise, not AH-wise).
This link explains why you want to use similar batteries way better than I could...
http://batteryuniversity.com/learn/a...configurations
Quote:
Two batteries in parallel halves the internal resistance. Or rather, the internal resistance is the same but are combined the same as 2 parallel resistances (which is always LESS than either of the individual resistances).
I find this confusing...
I went through training with Metra a few years back and we spent some time with Batteries...
I just looked some and I am finding that you are correct but we had a demonstration that would make you believe otherwise. Something other than internal resistance must have been at work with the demonstration we had.
It was a demonstration on why it can be a bad idea to use two batteries in parallel. The over all capacity is more but not 2x more as you might think.
They pushed that you really wanted to isolate the batteries from each other at any time other than charging.
We had 2 partially charged batteries of the same type and model and hooked them in parallel to a car. The car would not start.. Would not even crank over.
When you used just one of the batteries the car would crank over slowly but would start. This happened with both batteries.
So apparently it must not have been an internal resistance issue as I have thought for a few years now but something else entirely.
I have also seen reference to this when jumping a car as well.
Quote:
I am unaware of any alternator that uses diodes to charge 2 batteries. That requires 2 rotors and stators - ie, 2 alternators.
Alternators output up to 14.4V (steady-state) for 12V lead acids. [ 14.2V is a common set point. The older 13.8V spec has long been discarded. ] Alternators don't care what loads they power - it could be several paralleled 12V batteries - provided the alternator is loaded within its specs.
I HAVE one here... It is made by Wrangler. It is 130 AMP Hot/Cold rated GM compatible alternator with external Voltage Regulator. It has TWO outputs for batteries.
if you are using it with just one battery you MUST hook it to both posts with another wire. It is in storage so I could probably take a picture of it but I purchased it used and I believe the web site for the manufacturer is www.wranglerpower.com but I am not 100% certain since I do not see this alternator offered anymore.
Quote:
Who the heck uses diode isolators? Even in the old days, clever people used relays for battery isolation. (Which battery's voltage should the alternator sense?)
These days MOSFETs might be used instead of diodes, though I would still ask why (when a relay can be used...)?
I had one of these and I may still have it around somewhere. They had huge heat sinks on them and for proper use you had to tweak the voltage on your alternator higher to overcome the drop in voltage. It looked much like an audio amplifier. The large Diodes were potted inside the large heat sink and you had 3 connections. The common or Feed and then one each for each battery. Because I couldn't get my alternator voltage up I ended up replacing this with a constant on RV solenoid.
Relays are a bad idea unless you can get a very large Relay. RV constant use Solenoids are similar to starter solenoids but designed to be on constantly with large current capacities and for use in a dual battery system.
If you do a Google search for "Battery Isolator" you will find MANY of the diode style of isolator. It is very cheap and requires no extra hardware to run and won't wear out.
Probably used much more in Marine use than anything else.
Quote:
Your other points seem subjective else without any definition (eg "quality", or what outlasts a car battery in a car {and why would it be preferred}?).
Most of the companies I remember selling batteries made with "Ultra Pure" copper plates and similar designs don't appear to exist anymore. (US AMPS used to make some awesome batteries)
It appears that to get the type of batteries I was talking about you need either an Odyssey or Kinetik type battery but I am not as familiar with these as the older style batteries.
I had a long talk with one of the engineers for the Wrangler Alternator I had and he explained why the Optima Battery is a very BAD battery for car audio. He was the one that mentioned the US AMP battery.
What he told me is that the Optima Battery was designed for Off Road use mainly and for some racing applications. If used as the main battery in a car it will destroy your alternator eventually. Reason why is because as it discharges the design of it falsely requires higher and higher amperage to charge it. He told me a near dead battery shows to an alternator as a nearly 400 amp load and if you COULD charge it at that rate you would blow it up. Otherwise at this rate you will put a tremendous load on your alternator. He told me he could take a near dead optima battery and recharge it without issue but required a current limited charger which is not cheap. I went through 5 red top batteries and 2 alternators before I talked to this guy and it all made sense so I dumped the Optimas and got a US AMP battery. Doesn't matter now but that battery worked as well as the Optima battery, was half the size and I had NO issues with it even after 5 years using it as my main battery. I never had dimming headlights while feeding over 500 watts to my Subs or the other 200 watts to the other speakers.
