Hi
Your laptop wont reboot when cranking as it will automatically switch to its internal battery..What I did was run 2 wire runs to the boot, one off the cars accessory line and the other the ignition line both with relays.
The dc-dc inverter is on the ignition , amp,monitor ect run off the acc line.You will need to mod the laptops power switch http://www.mp3car.com/how-to-power-a...er-switch.html
or come up with another way to remotely switch on the laptop(there are a few different ways depending on your laptop hardware and bank account).If using windows as you OS you can setup what function the power switch will do when pressed whilst windows is running like power down ,sleep mode hibernate.You can also setup what you want the pc to do at certain internal battery levels in the power section (on mine 50% pc go's too sleep 5% pc shuts down)
LinkBack URL
About LinkBacks
).If using
