Results 1 to 6 of 6
Thread: Help a newb pick a PSU
    Oct 2012
    Sooo.. i'm sure this has been done to death already, but i couldn't find it.
    I have an older Mobo with 20 pin ATX and 4 pin p4 power connection to the board. Will the M4-ATX be the right PSU for me? Or does someone else have a different suggestion.
    Board has run with a 150W ATX PSU while it was being used as a POS system for a restaurant, So the M4 should power it fine, correct?
    Any and all constructive (or otherwise) criticism and suggestions appreciated.
    Thanks guys!
    Elsewhere
    You may be able to use an M2.
    I'd double check the power draw of the CPU before commiting to the M2, though.
    How about the Wiki?
    Oct 2012
    Quote Originally Posted by DarquePervert View Post
    But will the M4 work in this application?
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Yes the M4 will work, it has the 4 pin and 20 pin connectors for your mainboard and more than enough power @250watt. But if your buying and cost is an issue then the M2 would also be fine @160watt, just no room for powering other things off the 12v and 5v rails. Both are on sale at mp3car store. SNO
    Oct 2012
    Quote Originally Posted by SNOtwistR View Post
    Thanks SNO.
    Price difference between the two is not an issue. Would rather have a little more juice than just enough. Overbuild as opposed to rebuild down the road, ya know?
    Thanks for the help, as i'm sure this topic has been asked before by many other newbs, and i appreciate people taking the time to help me out.
    Nov 2012
    Thanks for sharing
  1. Not sure which sub to pick please help!
    By DTA in forum Car Audio
    Last Post: 10-12-2011, 11:31 PM
  2. Help pick a Amp
    By helllordkb in forum Car Audio
    Last Post: 12-30-2007, 10:08 PM
  3. Help me pick the right PSU. Please?
    By MastaShake in forum Power Supplies
    Last Post: 08-21-2007, 06:39 PM
  4. Please help me pick out an amp
    By mattwz in forum Car Audio
    Last Post: 06-28-2005, 11:10 PM
  5. One or the Other help me pick
    By mbkowns in forum LCD/Display
    Last Post: 05-17-2005, 04:44 AM
