In the sticky at the top of this forum is a Power Calculator. You don't need to know just the watts, but also how many amps per rail required. Then check out the data sheet at Opus to see how much it puts out on each rail. Be warned, the calc does not figure the CPU into amps per rail. You will need to convert the watts to amps depending on the rail it uses. I believe an AMD uses the 5V?
If you still got question, ask Kris at Opus.
For comparison, I currently run a P4 2.4Ghz, MSI MB, 512DDR, 20GB 7200RPM ATA 133, Radeon 32MB DDR on the 150W Opus.
LinkBack URL
About LinkBacks
), the only problem is, I've held off on the
