Results 1 to 6 of 6
Thread: High Pitched noise from Power Supply
    Feb 2003
    SE, PA
    My carputer has been installed and fully functional since February...
    about 3 weeks ago I turned it on and a very high pitched noise was coming from my center console. It lasted about 5 seconds then stopped.... wasnt sure if it was coming from the carputer or the PSu because they are next to each other but today I separated the two and its definately the PSU....
    Its a Keypower 250W DC-DC
    Its been getting progressively worse, sometimes it doesnt do it at all, sometimes 25-30 seconds....sometimes it wont stop at all and I restart a few times and it eventually stops...
    What could be causing this? Is it fixable without having to replace the entire PSU?
    Maximum Bitrate GuRuGoD's Avatar
    Jun 2002
    Omaha, Nebraska
    Sounds like a cap going bad to me.
    90% Done
    60W DC-DC & shutdown controller
    Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
    Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
    All in a shiny White 2000 V6 Mustang
    Click here to visit my NEW PhotoAlbum
    Jul 2002
    The magnetics in the supply can also vibrate creating audible noise if the switching frequency is right. You might be able to find the suspect part by touching the various coils with something insulated (or a dry wooden stick) to see if you can touch one and have the noise stop or at least change it. A dab of hot melt glue or silicone adhesive applied to that part might stop the vibration. Don't overdo it with big blobs of the stuff because that might affect cooling of the component.
    Alan
    Raw Wave
    Jun 2003
    Most likely its comming from an inductor, transformer or anything with a black metal looking object with wires around it =)
    If it never use to make that high pitch noise then your PSU is about to blow, reminds me of the old CRT monitor about to pop.
    Anyway as mentioned above by alanh, sure the noise will go away. Soon it may go away for good...thats when your PSU blows completely.
    You really have to find out which component is causing this, may not be easy though and even if you did find it, it may not be that easy to buy a replacement.
    Feb 2003
    SE, PA
    bump
    had the keypower out of commision for a while and was using a PW-70a. I just hooked it back up and it wasnt making the noise for 2 days or so, now it is again. Maybe somebody can give me new insight since the last post was 8 months ago
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
    Feb 2003
    SE, PA
    and another bump!
    Was fine all summer, now its back. Highly annoying to listen to until it goes away which is anywhere from 10 seconds to several minutes.
    Trying to avoid (or at least delay) because other than that, theres nothing wrong with this PSU. 250W, and it survives cranking. What more could I want!
