Results 1 to 2 of 2
Thread: How do you power two devices from a DC-DC Converter?
    May 2013
    I have purchased a Mini-Box DC-DC-USB and I need to power two devices at 5V. One can be powered by USB, so I believe I can power it by stripping the wires down and connecting them to the converter's power output. The second one is designed to plug into a wall, so I imagine I'll have to cut off the plug at the end and be careful to supply the correct voltage.
    So assuming that this is all correct, how would I go about powering the second device? Do I need to hook the devices up in series or parallel? Will adding another device mess with the current in the first one and if so, what do I need to set to ensure proper power levels for both of them? I understand how to set the voltage output on the converter, but I am unable to test it for myself at this moment.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by anthony62490 View Post
    Just splice the cable coming from the DC-DC and solder both wires in parallel. This will work fine provided the amperage coming from the DC-DC is enough to power your two components.
    Live mp3Car Facebook Chat
  1. Power USB devices
    By spdyscotty in forum Power Supplies
    Last Post: 11-09-2006, 06:54 AM
  2. Not enough power to USB devices >> Possible Solution?
    By Tuckie in forum General Hardware Discussion
    Last Post: 11-16-2005, 12:24 PM
  3. FS: Car Power Point , PSU, Power Supply DC - AC Converter
    By m_lazell in forum Classified Archive
    Last Post: 03-21-2005, 05:11 PM
  4. many devices need +5v -- how do you power them?
    By mattress in forum Power Supplies
    Last Post: 02-10-2005, 12:12 AM
  5. how much power does different devices take??
    By mrzigzag in forum Power Supplies
    Last Post: 06-05-2003, 01:41 PM
