Results 1 to 7 of 7
Thread: boost 12 to 14.5 v ??
    May 2010
    Herákleion, Iraklion, Greece, Greece
    hello forum. my car has a 15.6" led backlight lcd. i am trying to build a dc psu to power it directly from my pc PSU. the lcd's psu, supplys it with +5v and +14.5v . i can easily just add the 5v from my pc PSU, but does anybody have an idea how would i go to boost the 12v to 14.5?? the lcd drows 2A...
    if i try to power my test lcd (broken) , from the 12v instead of 14.5 , it does turn on, but i'm not sure , as it would be safe for the monitor to drive it that way...
    any input?
    Raw Wave
    Nov 2009
    dc-dc converter.
    May 2010
    ofc.. but my question is how to build one. or what will happen with the lcd of its driven by 12
    Raw Wave
    Nov 2009
    Why build one when buying is cheaper? Otherwise look up SMPS chips like MC34063, TL496 etc.
    Using 12V instead of 14.5V depends on the circuit.
    May 2010
    mainly cause, where i leave, those things are hard to find and for educational reasons as well. those chips seem good! i will also try the LM2577S-adj, which has adjustable output, and see how it goes!
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I just had to do this for my speaker/amp mod I just posted about. I used the DC-DC-USB converter as I had one lying around. But I do like the look of that LM2577 for such a small increase and you should be covered with amp draw. Good luck SNO
    Dec 2005
    Raleigh, NC
    You can find a simple adjustable step-up converter on eBay for really cheap.
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
  1. Boost to ECU
    By Joel Maxwell in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-25-2012, 05:34 PM
  2. Boost mobile?
    By PURDooM in forum Wireless Communications
    Last Post: 03-14-2011, 11:12 AM
  3. bass boost
    By tundra2000 in forum Road Runner
    Last Post: 07-17-2006, 01:10 PM
  4. bass boost?
    By Bboy_jon in forum Centrafuse
    Last Post: 05-18-2006, 05:38 PM
  5. OBD-II that shows boost
    By 2gttalon in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-05-2005, 09:53 PM
