Since I didnt get an answer on the DSATX thread, Ill try my luck with an own thread.
I have connected my DSATX to my amps and DSP with the recommended relay. It works fine, everything turns on flawless, but when I crank the engine the DSATX will cut the aux out signal and thus my amps and DSP will turn off for a few seconds. It is quite annoying, since it takes a while for the DSP to restart and sound to resume.
Is there any way to tell the DSATX to not turn off the aux signal while cranking?
Thanks in advance!
