Results 1 to 5 of 5
Thread: Ancillary power consumption
    Jan 2014
    Does anyone know how much power most usb ancillaries consume? Trying to work out how to spread the load over the hubs evenly.
    BT receiver
    Wifi
    Gps
    DAB
    3g dongle
    Cameras, assume some of these will have external power?
    Cheers
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Should they all not conform to the 500ma usb limitations (well 500ma or under)tho im sure the 3g dongle will be the hungry one.i have one that was supplied with a wall plug..its rated at 500ma but it has router mode also
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    They should all be 500mA or under excluding ext. hard drives they like 2 powers usually SNO
    Oct 2010
    Greece
    i think if you plugged it on a running computer you can see their real consumptions . there is also a software called "usb device view" which probably can be a lot of help identify each usb properties. i just plugged my 8gb donlge and it gives me 200ma.
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
    Jan 2014
    Cheers, will give that a go.
  1. Replies: 7
    Last Post: 01-26-2006, 12:35 AM
  2. Power consumption
    By Jimbo1978 in forum General Hardware Discussion
    Last Post: 07-07-2004, 11:00 AM
  3. power consumption
    By Sway in forum Power Supplies
    Last Post: 02-09-2004, 09:19 PM
  4. power consumption of a usb hub
    By cubanmoses in forum Power Supplies
    Last Post: 08-09-2003, 02:27 AM
  5. Power Consumption
    By Technics in forum Power Supplies
    Last Post: 05-31-2001, 11:37 PM
