Results 1 to 10 of 13
Thread: inverter issue
    Constant Bitrate cubanmoses's Avatar
    May 2003
    miami/orlando
    inverter issue
    alright, i've bene using my laptop in the car and i couldn't figure out why it was going real slow. i start to mess around wiht a few things and i decide to unplug the inverter from the laptop and let it run off the battery. when i did this, everything worked fine and the laptop was up to speed, i hook it back up to the inverter and it slows up again. I have a 90 W inverter for a laptop, i thought that this would be plenty of juice for it. what can i do to solve this prob other than get another power supply.
    project: built, updating software
    comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
    software: nlited xp, roadrunner
    screen: TM-701L touchscreen
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    future: gps with and navigation software
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    find out how many watts your laptop uses.. maybe it uses over 90W so like your cpu is slowing down due to that
    '98 Explorer Sport
    80% done
    May 2003
    miami/orlando
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    Jul 2003
    Milan, Italy
    I would use a filter or a small battery between the inverter and the laptop, the slowliness could be because of interferences....
    -NicGalla-
    custom-made aluminum case | MK2.8+ PSU | EPIA 800 | 256 Mb DDR | 120 Gb 7.2k WD | Wireless Chieftec mouse & keyb | Trust USB Keypad & USB webcam | Majestic TFT 7" 16:9 | WinXP & ME2 | connected to factory head-unit in a PT Cruiser 2.0L
    May 2003
    miami/orlando
    what type of battery or filter would work? i'm not experienced with this, and did some searching.
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    May 2003
    miami/orlando
    has anyone had this issue before? i've been searching and can't find an answer. i have the inverter plugged into the cigaretter lighter outlet, then the computer's power cable into the inverter. the inverter has plenty of power for the laptop, i can't figure out how to fix this problem.
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    May 2003
    miami/orlando
    c'mon guys, i know someone knows what to do in this situation. it shouldln't be cause of lack of power. could it be my cigarette slot, the inverter, etc??? it runs fine when it's running off its own battery though.
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    Maybe the wiring to the cig.adaptor is bad and it's getting a trickle of power .. I don't know... test to see what kind of power is at the adaptor..
    -Brad
    83 mp320i 285k
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    Constant Bitrate jpainter99's Avatar
    Aug 2002
    Get a DC-DC supply for your laptop. Inverters put out horrible AC. I put a O scope on mine one time after it burned up a nicad charger I was using to charge up some AA batteries and the waveform looked about as much sinusoidal as I look like denise richards.
    2002 Z-71 Rolling with an ITX MOBO, 10.4" touchscreen, 40 Gig HD, and a DVD ROM.
    http://www.truckputer.com
    Jan 2003
    Ruston, LA
    That's not true ! You DO favor Denise Richards !
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
