Results 1 to 3 of 3
Thread: What do you guys think about this PSU??
    May 2010
    Herákleion, Iraklion, Greece, Greece
    Hello forum. so, i am making my (hopefully), final install, which will be inside my dashboard, behind my 15.6" lcd screen (relativly large free area behind it ) . SO, for various reasons, i have decided i will go with DC to AC inverter, and use AC psu.
    (lets not discuss the pros or cons here )
    Where i leave, options are rather limited, so i have found this :
    http://www.fsp-group.com.tw/index.php?do=proinfo&id=342
    what do you guys think? it's supposed to be industrial level, and i dont know if this is good or bad !!
    Maximum Bitrate rray's Avatar
    Apr 2012
    SF Bay Area
    It looks like together with a DC to AC inverter would generate lots of heat and drain your battery. That type of power supply usually has a loud small fan. I would not mount it in my dash, maybe glove box install?
    May 2010
    the inverter will be all the way back to the trunk... plus, the set up wont use too much power, so i dont worry about efficiency or battery drain.. (i anyway dont use the pc when the car is not running) .
    But you are right about the the fan making noise... especially since its "industrial grade" it will be noisy... i have enother alternative, that is supposed to be "quiter" , but with a slightlu bigger form factor..
  1. hey guys
    By topman in forum Newbie
    Last Post: 10-15-2008, 09:58 PM
  2. X-Fi On It's way, now i need you guys...
    By Rousie in forum Car Audio
    Last Post: 05-19-2006, 02:35 PM
  3. Have you guys seen this?
    By jzgt in forum Off Topic
    Last Post: 10-12-2004, 11:52 AM
  4. what do you guys think about this LCD?
    By alphonsus in forum LCD/Display
    Last Post: 11-22-2003, 04:40 AM
  5. Replies: 1
    Last Post: 02-19-2003, 08:29 AM
