Results 1 to 10 of 11
Thread: Single DIN carputer: OPUS v. Mini-Box PS
    Aug 2003
    I am planning to build my in dash computer in an enclosure that will mount in a single DIN slot.
    The VIA board and a 2.5" HD would seem to mount no problem in an enclosure this size if using mini-box's snap-in PS board. (similar sized unit: http://www.mini-itx.com/projects/bantampc/) That recent car power PDF said "A fully built ITPS power sequencer" could be bought as well, though they don't seem to be for sale there yet. With this extra ITPS, it would seem that the mini-box setup could offer nearly the same functionality as the OPUS supply. Or am I missing something major here?
    The OPUS supply is an attractive solution, but its size concerns me. Is it possible to mount this PS unit along with the VIA mobo in a DIN (approx 7x7x2 in.) enclosure? Its hard to tell from pictures if there would be clearance. The PS board would have to be mounted over the motherboard in order to fit in the DIN sized space. From pics it looks like it may be too large...perhaps someone with a unit can shed some light on whether this woudl be possible? In addition, a 2.5" HD would need to mount in this space above the board as well...tight fit is ok as long as it would fit
    Thanks for any help you can offer!
    [Whoops, I should specify that I will be using an EPIA M10000 board, as the component placement and HS/F parts on each board may be a factor as well)
    -SiliconIce
    Aug 2003
    Seattle, WA
    Ah, a powerful 1-DIN 12V powered PC!
    "powerful" is the key word...there are 1 DIN (or smaller) PCs, but they can barely run Windows XP (a sad litmus test for "powerful").
    Consider *NOT* trying to put the PSU inside the computer.
    I have a hack that I am propose for the Travla C-134 on this page at my site:
    http://www.swooby.com/z/navpc/computer.htm
    It's a tight squeeze, and cooling might be an issue, but it might be worth checking out.
    I also recommend some power options that might help you out:
    That PSU they use in the Bantam IS one of, if not THE, smallest PSUs on the market:
    http://www.mini-box.com/pw-70a.htm
    Even then, I think it is too large to make a 1-DIN ITX case possible.
    So, definitely consider mounting the PSU externally.
    I am looking in to a 2-DIN PC myself:
    Pv
    Aug 2003
    Nice pics you had, would be even better to get a slimline DVD drive into the DIN size casing...probably not really possible, that would be packed, but looks like your Travla box would almost do it. But I'll still settle for just HD and internal powersupply i want the device to be easily removed from the car.
    I have seen the mini-box board, looks nice, but it doesnt have the car-friendly features of OPUS. However, the mini-box people mentioned that additional board that they don't (are not yet I guess?) selling that would improve things. Guess I can make one myself, but I'd rather have one I know works for something like power.
    -SiliconIce
    Aug 2003
    Seattle, WA
    I still say it is possible to do this...
    ...to this...
    ...and have a 1-DIN computer, but again it would require moving the power supply externally (which shouldn't be a big deal).
    Pv
    Aug 2003
    Seattle, WA
    Then again, these devices are pretty cool (but less powerful):
    http://www.mini-box.com/m100.htm
    Pv
    Aug 2003
    So...assuming I could build one of the ITPS devices, are there any advantages that the OPUS would provide over the mini-box supplies + the ITPS? (I don't really see any so that's why I ask)
    -SiliconIce
    Low Bitrate stkdidy ntshidy's Avatar
    Jul 2003
    california
    Quote Originally Posted by SiliconIce
    its already designed for you?
    its already built for you?
    but you already mentioned that, so i don't see many advantages
    2005 Mustang GT:
    12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
    want: my stereo actually IN the car
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    why do you want a computer in your dash? Dont you want some type of display there?
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by paulpv
    Pv
    I like, who makes the case and where can I find it ?
    Terran
    Aug 2003
    Seattle, WA
    Quote Originally Posted by ccsnet
    Terran
    Casetronics - http://www.travla.com
    It's model C-138.
    It is not available yet, but it will be very soon.
    I think it is a bit too wide to be a true 2DIN unit.
    It may not be a problem for my car; I would need to get out a tape measure to be 100% sure.
    Pv
