Results 1 to 6 of 6
Thread: power inverter ruined ABS?
    Aug 2003
    Atlanta, GA
    My ABS light just went off. Here's what happened: I plugged in a power inverter in my cigarette lighter to test some GPS software and it works fine until I see smoke coming out of the exterior front passenger vent, near the windshield wiper. I turn everything off and it smells like urine! Then I turn everything back on again and I'm fine for a few minutes, then my power inverter shuts itself off, my audio system goes out, and the ABS light comes on. I pull over and turn everything off.
    Then I try running the sound system off just batteries and it works fine, but when I turn to accessory, I get loud feedback from my subs and nothing works. When I turn on the engine, the system works, but only after getting feedback from the subs. My circuit breaker didn't open and none of my audio fuses were blown. What do you think the problem could be?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Complete speculation, but perhaps you drew too much current through the cigarette lighter wiring and damaged a wiring loom somewhere?
    It's usually best to wire inverters to the battery directly since they can draw quite a lot of current.
    Rob
    Newbie Zensay's Avatar
    May 2003
    Denmark
    I Think you have some wires that are meltet together, chek the cabels/ wires near that air went.
    M10000,256 DDR,80 Gb, PCI TV/Radio, D-Link Radio, PCI Audigy 2, Opus 150W, BU-301, Bluetooth, Wifi, Lilliput 7" Touch, Ifree RF Keyborad, USB 2.0 HUB, 2 Amps 600w 4 ch - 620w 2 ch, 6*9" 4-way(rear), 12" Alpine (Sub), 4" 3 way(front), center missing.
    Newbie skiingsean's Avatar
    Jul 2003
    Dido.. The Urine smell you smelled was most likely the wires insulation being fried, and you're right it does smell like urine. So in my opinion you should be ok with nothing more than a set of fried wires. You probably fried the 12v lead that powered the cig lighter and melted a few more near by causing the ABS light to come on and maybe a few more things you haven't noticed yet.
    Good luck.
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    Quit ****in In your Engine Bay!!!!
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Could be worse.
    Blonde pulls here VW Golf Vert into the service staion.
    Asks the mechanic what the problem is.
    He pulls the car to pieces, then after about 20 mins, your he spots the problems.
    turning to the blonde, he says " Problem is, you got a 'crap in the airbox problem'".
    Blond looks puzzled for a moment, then replies, "OK, makes sense. "How often do I need to do that?"
    4x4 in a turbo stylee.
