Results 1 to 8 of 8
Thread: PC reboots when starting engine
    Jul 2000
    Jackson, MS, USA
    For example, when I fill up with gas but leave the key on ON its fine, but when I turn the key to start, the voltage drop causes the PC to reboot. I'm using one of zootjeff's DC to DC power supplies.
    Any ideas on what I can do? would a tank circuit fix the problem?
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    ya build a tank circuit
    '98 Explorer Sport
    80% done
    Jul 2003
    So Oregon
    You can try a .5 > 1 farod cap used for car audio to keep the current up while cranking, if that is your problem. 1 farod would be overkill, but half farods are hard to find (for me anyway).
    Jul 2000
    Jackson, MS, USA
    cool. does anyone know where I can buy the mbr3045 diode and a 25v 22000uF capacitor?
    2000 Honda S2000
    Jul 2000
    Jackson, MS, USA
    Quote Originally Posted by e_fractal
    But .. how do turn on your PC? It could alao be a problem with a remote wire off your ignition, pending how you hooked it up.
    I have it wired into the fuse panel under my driver side dash. it has 3 connectors for a spade connector. one is always hot, one is hot when key is turned to ON, other is hot when headlights are on. I have it wired into the one that becomes hot when key it turned to ON.
    2000 Honda S2000
    Jul 2000
    Jackson, MS, USA
    I found out that my car has a relay that drops power from there while cranking, and I was told of an alternate power source before the relay to use.
    2000 Honda S2000
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    most cars cut the acc power wile cranking - my 2000 Civic does this through the key switch.
    You learn a lot when you install remote starters
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    gotta love the Opus for things like this. Build a tank circuit.
    Mine needs to be updated.
