Page 1 of 33 1234567891011 ... LastLast
Results 1 to 10 of 330
Thread: Sprrogy MK3.0 coming soon.!!!
    FLAC Mastero's Avatar
    Aug 2001
    India
    Sprrogy MK3.0 comming soon.!!!
    Hello friends ,
    Just completed the MK3.0 design. and received the PCB for it. shall test it in the next 24hurs and post the result here with ALL details.
    Spec:
    3.3vdc --- 5amps
    5vdc -----10amps
    12vdc-----2amps
    -5, -12, stby everything on ... full ATX features......
    "NO MORE t6"
    ISOLATE THE MBR745 AND THE MTP3055 ON THE HEAT SINK
    CHANGE THE IN5819 TO IN5822 SORRY ABOUT THAT.
    Cheers
    Mastero
    Aug 2002
    longview washington
    does that mean the parts will be easier to get?
    how much of the old parts can be used witht he new setup?
    i got a few of the parts just never got the rest of them to finish the older version
    WINNER!!!!
    run-on sentance comp 2002!!
    Aug 2001
    India
    Please wait for a while shall post all details up here with components list
    Mastero
    Newbie Kalavera's Avatar
    Jul 2003
    Ireland
    Talking
    Quote Originally Posted by Mastero
    Mastero
    Ooh, I can't wait. I feel like a child at christmas!!!
    Current Cfg: AMD 2200+, Epox Mobo, 7" Lilliput TS, 320MB RAM, 40GB 2.5" HD, 200GB SATA, Slim Combo, ATI Radeon, SMC B/G Wireless w/ 5dB antenna, Bluetooth.
    S/W: RoadRunner/MapMonkey/NetStumbler. Still working on a box and PSU!
    Jul 2003
    Do you like?
    Hi from Spain, Do you like it?
    Description/Specifications
    Dimensions (mm) 160 x 45
    Input Voltage Required (V) 11.4V~12.6V
    Maximum Output (W) 62.4
    Output Voltage V 5VSB +3.3V +5V +12V -12V
    Current A 1.5 4.0 4.5 1.5 0.1
    Power Output W 7.5 13.2 22.5 18.0 1.2
    Peak Current A 2.0 8.0 8.0 2.0 0.2
    I have got one unit and is perfect to mount in a car. Price 30.
    Taluego...
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Your car voltage will go up to 14.4V, thereby breaking the input voltage requirements. This is not very suitable for car use without a regulator on the input. This has been covered many times before.
    Jun 2003
    Marvellous, give us an update ASAP please Mastero
    Regards,
    nick.
    Jul 2003
    But with a lm78L12 I can regulate the voltage to 12v. It works to me perfectly. Hasta luego
    Apr 2000
    Bedfordshire, UK
    The 78L12 is a 100mA regulator, which is not enough. In addition it is a linear regulator (and requires the input voltage to be higher than the output by about 2v). Again, this has been covered many times before, I'd recommend you do some reading.
    Jun 2001
    Boise, ID (USA)
    Yes, it does work, provided you dont run any 12 volt accessories. Running a regulator will drop you down to some pretty scary voltages which could give you some equipment problems down the road.. I had this setup just to see how it worked and my biggest complaint was that it will not ride thru starting up your engine, this is a major pain... Not a bad cheap solution, but not perfect..
