Results 1 to 10 of 11
Thread: How long...
    Sep 2003
    Vic. Australia
    How long...
    I know this is a bit of a vaigue question, I was wondering how long people think it is safe to have an in-car pc on after turning the car off without the battery going dead. System is an VIA M10000, Opus PSU, 3.5" hdd.
    Mainly asking coz I wanna be able to go inside and remote access the system without having the car runing (for at least 30mins) without anything bad happening next time I try and start my car.
    Graham
    Newbie Zensay's Avatar
    May 2003
    Denmark
    That wil go just fint, The opus has a built in battery protection. but restarts a moment after 8-(. I have my system to test, and it run over 60 min on a 24 Ah battery, and the one in your car is dubbel that.
    Sorry for my bad english
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    you'll be fine. I've run my system for 90 minutes with no problems. I use a 300 watt inverter and a 800 mgz amd
    '98 Explorer Sport
    80% done
    Maximum Bitrate freestyler's Avatar
    Jan 2002
    Chaska, MN
    one of the guys from minnesota had his on for over 6 hours and it was fine
    1997 Jeep Wrangler Rugged Waves
    Ebay Stuff For Sale
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    I've had my comp on that's powered by an opus (and is powering my monitor) and my radio on for about 3 hours and it started....but it was a little questionable.
    BossTone74
    Jan 2002
    Chaska, MN
    Quote Originally Posted by bosstone74
    i seem to remember one time it not starting
    just had to poke fun at ya!
    Ebay Stuff For Sale
    Jun 2003
    Atlanta/Augusta, GA
    battery protection is questionable...
    I've run the opus and car audio system for a pretty long time without the car on but key in the ignition. Car was in the garage for 3days straight. I had winamp playing while detailing and working on the install. Not sure of the exact opus on time, but probably much more than 6 hours with an amp running.
    When battery was on its last limbs, xenarc started flickering. Shortly after, the opus triggered a windows shutdown. If you have a program that wont close when shutting down windows, don't count on the battery protection saving you.
    Because the key was still in the igntion, the opus fired back up. I didn't wish to take any chances of a dead battery, so I tried to crank it. First attempt failed. Second was no better. I thought I was sol.
    I finished up whatever I was working on and grabbed a cool drink. I turned off all the gizmos and unhooked the opus and gave it one more chance. It finally started. Under winter conditions or older engine/starter, I'm not sure the battery cutoff would be good enough.
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Clearly the opus cutoff isn't enough. I have seen aftermarket devices before that attach right to your battery though and will cut all power to the car if the power gets low. That would probably be the best way of assuring that everything will be ok. I've been thinking of keeping a spare battery in the trunk for the day I do something stupid like leave the key in and tank my battery, that way I can just toss the old one and throw in the new one. (my current one is a few years old and I've run it dead once).
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Dec 2002
    Illinois
    Quote Originally Posted by fluffy2097
    Why not go one step further and wire it up throw a switch in and use it to jump your original if it goes bad
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    I have two batteries, one that runs my starter and all the car's electronics, and then I have a second battery that runs my carputer and all my amplifiers etc.. that way I can listen to my carputer until it's battery is completely dead, and then just start the car again, and it will kick back on.
    In order to do this, you need a multi battery isolator, which you can find for cheap on eBay, I bought mine for like $10.
    It also works as a tank circuit! so that when you are cranking the car, the carputer stays on!
