from what i could see its only a step up regulator, so anything above 12 is bad news.
look at the typical operating circuit on the first page
I was looking into step-up/step-down voltage regulators for providing a constant 12v to my LCD and I ran across the MAX1771.
http://pdfserv.maxim-ic.com/en/ds/MAX1771.pdf
From the datasheet, it looks like it can take in 2-16.5v and produce 12v out at 24W. The price is < $2. Am I overlooking anything, or can I just build the reference circuit and have a simple regulator?
--Tom
the MAX1771 is a step up chip only. Yes, it takes 2 to 16.5V but the output is adjustable, not just 12V. If you wanted to have the input from 8V to 14V with a 12V output you would have to use something like a LM2587 from National Semiconductors in a flyback regulator setup. The sproggy used to use this setup but has been changed to a MAX1771 in its latest reincarnation due to the difficulty in getting parts. Do a bit of a search through the Sproggy power supply threads and you should be able to find the answers to most of your questions.
