Opus power supply issue
I have a strange issue I wanted to see if anyone has seen this before. If I turn on the PC with a switch (Opus is not connected to the power switch jumbers) the pc will turn on, what I want it to do.
I have XP set to when the power button is pushed it logs out of xp and shuts down the PC. The issue is after this is done I can no longer use the power switch to power up the PC.
The only way to power to PC back up is to unplug the Opus from the power source and reconnect. Just for info I have the power supply powered from leads from my car stereo power source with the Yellow and Red wires hooked up togeter to the power source and the ground to the groubd.
Any Ideas?
Danny
That would leave the opus triggered on.... uhm lets see - I would hook the yellow (Ignition) wire from opus to the remote amp / rem power from your head unit...
Then check your bios for "AC power loss" or "resume after ac power fial" turn that on... I tihnk this would solve the problem.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
