Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Opus PSU for Casetronic C134
  1. #11
    Newbie entr0py's Avatar
    Oct 2003
    NH
    Quote Originally Posted by aethernaut
    Wait a sec, my thinking might be all screwed up here. I was going to leave the casetronic supply in the case (that way I donít have to deal with the 16wire ATX connector), extend the 12v wires from the Opus supply, and use that 12v to power the whole thing. But this may not work at all. The 12v on the Opus might not be rated high enough to do this, plus, I might loose the ignition sense and off delay features. I guess I wonít really know Ďtil I get the Opus unit and see how it works.
    Does this sound feasible to you, Jeff? See what a pain this is not having the supply INSIDE the cabinet? I would be in a better position to tell you how much yours would be worth, after I get the Opus and see what it does. What Iím after is a smooth power-up of the computer when I turn on the ignition. When I shut off the ignition, I want the computer minus the display to stay powered up for about an hour, and then a smooth, automatic shutdown. The thinking is that this will do two things, I hope: Allow me to transfer files over the wireless net without having run back out and shut everything off afterward, and prevent a boot cycle from just having to run into a store for something.
    A bulkhead connector is same a regular connector, but usually with little tabbies to hold it in a slot in the case.
    -Jon
    I never thought of doing it that way. I would think you would loose the functionality of the opus if you only use the 12v line, but I am not sure. I would e-mail or call Kris at opus and ask him.
  2. #12
    Oct 2003
    NH
    Quote Originally Posted by zootjeff
    I actually have a version of the MPBS1 that I put into the casetronic case. It doesn't have a shutdown controller built in but the 12 volts is regulated and the total output power is 70 watts just like the MPBS1..
    What would a good price for it be?
    hmm, i dont know what a good price would be. The opus is rather expensive. I bet more people would buy it if it was lower in price than the opus. Is there any room to fit the shutdown controller built in? would you offer any type of warranty?
  3. #13
    Variable Bitrate Cyberphox's Avatar
    Sep 1999
    New Glasgow, Nova Scotia, Canada
    And what ever happened to this
    Quote Originally Posted by entr0py
    Technology, Gadgets and Making Money Online
    http://www.genemills.ca
  4. #14
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Quote Originally Posted by Cyberphox
    he is selling it and you can buy the PSU and the shutdown controller for less than the opus.....but its only 70 watts. Check out www.mpegbox.com for more info.
  5. #15
    Sep 1999
    Power Supply $120
    Shutdown $30
    Opus from mp3car store $150
    Not much savings there...
