Results 21 to 30 of 40
Thread: 12v Regulator Schematic (15A)
  1. #21
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Well I will build this circuit and test it out with a full ATX mobo(config within 120W) to see if it has any problem. It wouldn't hurt to burn one of those rather than the via M1000N because I have some of those P3 PC laying around doing nothing.
    Maybe we can extend this circuit to be the shutdown controller.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #22
    Maximum Bitrate MaleBuffy's Avatar
    Aug 2003
    Greece
    Could do......I am waiting for your test results!
  3. #23
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    This is essentially a linear regulator. There is no way it can sustain a 12v output with less than 12v input. You pay a Vbe drop across the 2N3055. Those simulations that indicate the output is 12v with an input of 1.5v are misleading to say the least. To boost voltage you need AC and reactive components (that voltage will be coming out of charged capacitors, and under load will discharge fairly rapidly).
    Rob
  4. #24
    Raw Wave
    Jun 2003
    Yup, the simulation is not correct...try to stick in a 2.4Ohms resistor as a load.
    Also your supply is going through a 1KOhms voltage divider. The supply voltage need to be very stiff. A car battery is capable of supplying very high current. So in your simulations you should supply alot more current if you gonna drain 5A.
  5. #25
    Sep 2003
    Beach City, Socal
    Well the 1KOhm voltage divider is there to simulate the change in the car voltage. It's not there in the original schema.
    I know the car current is much higher than what in the simulator, but at least it show the state of the output voltage.
    With a 1.4Ohm resistor connect in series with the last volt meter, the drop is a bit faster but it still showing 11.6V for about 5 min when input @ 7.5V.
    BTW, I am not an EE guy so I don't know much about the electrical stuff.
  6. #26
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by MatrixPC
    Put it in parallel with the voltmeter to simulate a load. Ie, output down to ground.
    Rob
  7. #27
    Raw Wave
    Jun 2003
    You guys are doing well though
  8. #28
    Sep 2003
    Beach City, Socal
    Man in parallel, it's a different story.
    Anyway, I will try to build the circuit and stick an 100W H3 bulb in there as the load to see what happen.
  9. #29
    Apr 2000
    Bedfordshire, UK
    And the story is what? Does the voltage drop off real quick by any chance?
    Rob
  10. #30
    Sep 2003
    Beach City, Socal
    Well at 14.5 V input, the output is at 11.8V. It drop down to 8.5V if the input is at 10V.
    If you guys wanna try it out, the software is Preteus 6 by Labcenter Electronics in UK. I am using the demo version so I can't save the design.
