You can also buy these directly from Jeff, the man who came up with this circuit: http://home.comcast.net/~zootjeff/shutdown/
I paypal Mastero for a SDC but got refunded so I digging thru the forum and found this schema for SDC http://home.comcast.net/~danielsoh/img/atxshutdown.gif originally design by some member of this forum. I try to recreate the circuit and run thru the simulation to see how it work before building one but the result of the simulation is not what I expected. I am not sure what is wrong, and I am not an EE guy.
Notes that I change the Trimpot from the image above to regular resistor and base on R*C = Time(second) to estimate the time.
I think/expect this is how the circuit works.
- ACC/Control line ON -> and after a few second -> Switch ON Inverter/PSU.
- ACC/Control line OFF -> Rundown time (some minutes) -> Press/Simulate ATX PWR switch to turn off computer -> Rundown Time (Some minutes) -> Switch off/Cut power to Inverter/PSU.
- Kill Switch -> cut power to Inverter/PSU.
Attachment in order.
1st image: before the simulation run.
2nd image: 8.5 Seconds into the run (the chema app cpu power is ~100% NOT system CPU). I switch ON the ACC/Control line.
3rd image: 45 second into the run (~35 sec after ACC ON) the Inverter/PSU line is switch ON. This is as expected but too long. I may change R3 value to make it shotter.
4th image: After 20 min into the run, I switch OFF the ACC Control line. NOTHING is happen after that. No ATX PWR switch press and power to PSU/Inverter is NOT cut off (I understand that there are rundown time control by C1 VR1 and C3 VR3). I wait for 10 min (~2min is my setting) after ACC OFF to see if the ATX PWR signal is generate but NONE. Another 10 min (~2min is my setting) for cut OFF power but NONE.
Can someone show me what is wrong?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I may want to get one later but for now I really want to know what I did wrong with the circuit. It really bug me why I can't get it to work.
Originally Posted by ciagon
Now that sounds like a difficult way to do an easy thing.
I know this circuit is working cuz people are using it.
As of my current setup, I don't really need this shutdown controller, but it's nice to have one because I have to hit the PWR button to shutdown the computer. The Alarm Remote Start/Turbo Timer will taking care of quickstop and shutting down the Inverter/PSU. The mobo "Resume on power lose" taking care of the booting.
Don't you hate it when something is not working for you but others?![]()
