Results 1 to 10 of 18
Thread: Poor Mans Opus
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    SoCal
    Poor Mans Opus
    Ok, this Opus lead time is killing me. I reasearched into doing my own board layout, but that could take a few weeks. So upon further research, I came up with the following solution.
    DISCLAIMER: Solution requires knowledge, experience and skill of electronics. This is not a plug and play solution, rather it will require some effort on your part to put it together without blowing $hit up.
    According to the www.mini-box.com power calculator, you need the following voltages for my Epia-M 10000 system. Your system may be different, so go check out the max current draw for your configuration.
    3.3V @ 3.4A
    5V @ 3.2A
    5V Standby @ 140 mA
    12V @ 1.26A
    For 5V, I found this:
    http://www.jameco.com/cgi-bin/ncomme...search=AA9090A
    for $6.95, works from 5V - 20V outputs 5.1V @ 3.75A
    For 3V, use a 2nd 5V module and add this:
    http://www.jameco.com/cgi-bin/ncomme...earch=219150cf
    for $6.95 plus $10.25 , works from 5V - 20V also and should spit out 3.3V @ 5A
    Now for 12V, use this:
    http://www.jameco.com/cgi-bin/ncomme...earch=217234cf
    Its $45.95 and only works down to 9.2V up to 18V. Puts out 12V @ 2.1A
    So for 70 bux plus a few hours packaging and wiring, you could have a fairly efficient 60W DC power supply that runs down to 9.2V.
    If I could just find a cheaper 12V solution that runs down to 7V, then I might just try it.
    www.mechatroniks.com/wrx - Car PC Project/Dash Kits
    Constant Bitrate mugu's Avatar
    Oct 2003
    San Antonio, TX
    Ignition switch!
    Low Bitrate aethernaut's Avatar
    Oct 2003
    Chicago
    I'm just about coming to the same conclusion as you, phc. Now that I found out that my Opus really wasn't in stock and it'll be 4 weeks. In 4 weeks here, there could be a foot of snow on the ground. Everything else on my project is ready to install.
    I suppose you could add zootjeff's powerdown timer for another $30, but now you'd be at $100 and still wouldn't have the ignition sensing. And If I'm going to build something, it's GOING to fit inside the C134 case...but what the hell, now I've got 4 weeks with nothing to do but twiddle my pud on this anyway.
    "Close only counts in horseshoes and hand grenades"
    VIA M-9000, C-134, 256 Mb, DVD-CD/RW, 60 Gb, XM-PCR Sat Radio, Linksys 802.11b, Street Atlas GPS, ReplacePCR XM s/w, Blaupunkt HU, Sony XPlode 5 ch/amp, Liliput 7" VGA
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    http://www.dashmatics.com/product_in...fe1a332d0d09ee this shutdown/startup controller and a simple dc psu (pw-70 or 12ow of ebay or sproggy) would be just like an opus (kinda) feature wise. this is what I should have done
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
    phc
    phc is offline
    Aug 2003
    SoCal
    Quote Originally Posted by guitar333
    Hey, the DSSC is out of stock also.
    No snow here, just want to have this thing done for Thansgiving so I can enjoy that 8 hour ride (that should only take 4.5 hrs) up to San Francisco.
    I got a few BasicX's laying around, I could use that to whip up a startup/shutdown controller with remote turn on, delayed turn off, etc.
    Maximum Bitrate none's Avatar
    Sep 2003
    Why not the MPBS1? http://home.comcast.net/~zootjeff/ You can get these shipped out fast.
    Or get a sproggy from mastero and see if you can be the person who gets it working with the m10000. That is likely to be easier than building a PSU from scratch. I'm using an epia 5000 so it works great for me http://www.roshanindustries.com/carmp3/shop.htm
    Low Bitrate DinoBite's Avatar
    Oct 2003
    socal
    175 bucks
    its like, 2 cents of plastic and copper
    sigh
    Sep 2003
    Quote Originally Posted by DinoBite
    175 bucks
    sigh
    Then make one yourself. The plans are out there if you .
    Oct 2003
    socal
    Unhappy
    I don't have two cents.
    But I do have a copper pipe that I found in the street, I'll just smelt it and make my own, uh, coppery stuff!
    Oct 2003
    Chicago
    What about the plastic?
