pretty much the same way as in inverter but the opus has a shutdown controller if you want to use it. Which means you'd need to hook in another line to your ignition or such.
Okay, I been reading around trying to figure everything out for myself so I didnt have to bother anybody w/ my questions, but I can't resist. I've saw the pictures of the Opus PSU, how exactly do you hook them up? I understand how the inverter would be hooked up, but I'm not seeing correctly how these ones work.
Thanks..
'98 Explorer Sport
80% done
it replaces your current ac-dc power supply inside you PC. an Inverter just supplys AC to your current power supply.
