more powerful dc/dc ??
ive been searching around for a while, but i still have a couple questions. i have an amd xp2400 laying around that i want to put to use, i still need to get everything else to go with it, but its going to take a good bit of power to run? i was planning on using a dc/dc psu but what does it take to get a dc/dc with enough power to run 2+ghz systems? from what i can understand the power is there, it is just hard to regulate it correctly with alot of amps / watts needed to supply? this may be way out there cause i dont know much on electronics, but can you run more than one power supply some how to increcase the watts?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
