Sounds a bit too technical for me, but..... I don't suppose you have any pics of your set up do ya...??I wanna Prelude myself...
Hi
I had an SV24 with a DC/DC PSU from MGPower and ran a 600w AMP @ 30 AMP.
I now have a regulated C134 EPIA-M and run it off the same system, i.e. a second battery in the boot/trunk. The problem I have is that the PC and AMP on together will drain the battery in 20 minutes flat. I can only surmise that the relay is not charging the battery. I get 14.3v at the main battery terminal and going into the relay but ony 12.3v at the second battery terminal on the relay and on the second battery terminal.
The relay has
Power In from main battery
Power Out to second battery
Fridge Power Out
Ground
Ignition light
When I take a reading off the ignition wire it only reads between .1 and .15 of a volt, I thought that this may be the cause?
Basically the voltage off Power out to the second battery seems to be just the voltage from the battery and when I power up the PC it just steadily drops about .1 volt every 40 ish seconds
I have searched the forum on split charge relays and found some interesting links and coments made on the "Black Art" of Lead Acid battery charging
Any help welcomed
Lilliput 8", C134 EPIA-M 900 (Black), A1-ITX, 256 Mb RAM, 40 Gb HDD, DVD, 802.11g, mini keyboard
I do but they are of the old setup, I had an sv24 and a 10.4" screen but I got sick of the size of the screen and the space that the sv24 took upOriginally Posted by Spaghetti
http://www.btinternet.com/~jonathan_porter
The site will be updated as soon as I solve this power issue!![]()
That's a lotta wires!
It definately sounds as tho the second battery is not being charged. If you could draw a diagram of how it is wired up I will be able to help you. Obviously your alternator is working because you have 14.3v at your main battery. If you have wired it up correctly, when the car is running you should have about 14V (varies due to resistance in wire from alternator to the back of the car.) at the second battery.
My first suggestion is double check all your wiring.
There's a lot less nowOriginally Posted by Spaghetti
Thanks for this. Its a bad diagram but it gives the idea The wire to the rear battery is a heavy guage and about 2 metresOriginally Posted by meddler
I don't know what else to try at this time.
It should be wired up as shown in the pic below. I have drawn in the connections for a standard bosch type auto relay, but you should be able to figure it out if you are using something else. It sounds as tho you have the relay wired up incorrectly. Any more dramas let me know.Originally Posted by slarty
85 does go to ignition on but it goes to the ign on the head unit loam. is .1v enough to switch the relay. Also does the relay switch immediately to charge the second battery as it has the ignition on.Originally Posted by meddler
Thanks for the help!
most 'ignition' inputs need 12v to trigger. sounds to me like that's the culprit
