This is how I had mine setup.
4GA
power wire run directly from the battery to the trunk and connect to the inverter and amps (distribution block).
4GA wire for inverter ground and 4GA wire for amps ground at the same spot.
One end of the 2 wires connect from the Inverter's ON/OFF switch and the other end of the 2 wires is connect to pin 70 and 30 of the relay.
Pin 85 connect to ground (same spot as amp and inverter)
Pin 86 Connect to IGN ON.
So when I turn the key to the IGN ON position, the relay is ON and connect pin 70 and 30 together which in turn "Push" the inverter ON/OFF button to ON.
I have enable "Boot when AC lost" in BIOS setup so that when inverter is turn on, computer boot.
On shutdown, I have to hit the computer power button to hibernate/shutdown. After the computer shutdown I then turn off/remove the key which switch off the relay and that "push" the inverter's switch to OFF.
The shutdown controller DO NOT bush ON the computer for you.
The shutdown controller purpose is allow you to run some amount of time (adjustable) before "push" the computer power switch and switch off the inverter/PSU.
If you can wait for your computer to shutdown then remove the key, then you don't need the shutdown controller.
As of my setup, before I want to shutdown the engine, I just press the button on my car alarm remote control to enable the turbo timer (engine running without a key), remove the key and or press the PC power button. Walk out the car and look the door while the engine is running and the PC is shutting down (PC shutdown like in 10-15 sec). After I walk about 50 feets from the car, press the remote again, car shut down or I just leave the car running untill the timer is up (6 or 12 min).
